1st Gen R53 Cooper S Fender Wells (What to Cut?)
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by M^Cubed, Sep 29, 2009.
  1. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
    What do people usually "dremel" when modifying the fender wells to accommodate larger tires?
    It seems my tires have done most the work on the arches and liners, but have no taken an appetite for the seam. The tires have bent the seams flat in some spots, but others are still pretty scary. My tires are looking pretty beat up from the whole thing.
    If I add negative camber it will only push the bottom out further - I am pretty sure this wont help with my problem. Do people hammer these seams flat or cut them off and paint them?
    P.S. This is all in the rear - the front is perfectly fine.
    (215/45/17 on 17x7.5 et40)
  2. PGT
    PGT Wheel Whore
    Federal Gov Contracting
    Leesburg VA
    you have rubbing problems? I ran several 225's on my car and never rubbed inboard.
  3. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
    It is on the outside edge. They are Dunlop Z1's so they are rather wide with the 45 aspect ratio. They measure 9.4" section width on a 7" rim.
  4. BThayer23
    I run that same setup - 215/45-17 star specs on 17x7.5 wheels and TSW springs. Mine took about 10k to wear away the fender liner. You'll see strips of plastic on the tire where the tread blocks cut away at it. First they rubbed on every bump, then they rubbed with a passenger over bumps, and now they don't rub. The fender liner has a jagged crescent-shaped cut where the outside edge wore it away. I thought about Dremeling, but procrastination paid off: it doesn't make any more noise and nothing's falling off the car.
    BTW, it was just the fender liner that got cut, not the plastic wheel arch trim. You may have a different situation - I'm not sure what seams you're referring to.
  5. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
    I've worn down the liner - completely gone in basically all the area towards the aft of the car. The arches are worn down fine too. Now the bodywork seams are underneath the fender liner where actual metal unibody arch is seamed at.
    I'm probably lower than the TSW springs by a bit - my tire tucks into the fender at rest (coilovers down pretty aggressive - not "Rally" low though.
    I can tell that the seams used to be pointing down towards the ground, but the areas that the tire hit have taken the paint off and flattened them a tiny bit.
    I've had 215/40/17 Star Specs on my 17x7 et38 - those *almost* don't rub anymore except over the nasty bumps. The new 215/45 rubs on pretty much all rinky dink stuff. Smooth sailing on the freeway *almost*
  6. quikmni
    quikmni Moderator
    Jun 6, 2009
    774
    174
    Aerospace Engineer
    Orcutt, CA
    I too am curious about what people have done for the metal contact areas. I have 215/40x18 on 18x7" wheels with JCW springs and about 37mm offset with wheel spacers. I have rubbed through the plastic liners and arches in a few places, so most rubbing has stopped. However I can see a couple places where the tire rubs on metal so I would like to fix those areas. I have no tire damage (just rub marks) but I do not want to push my luck, especially on the track.
  7. checkers
    checkers Well-Known Member
    Jun 11, 2009
    4,338
    994
    Modesto, Ca
    I,m running 225x45x17 on 17x7 and I haven't had any rubbing problems inside or out. I'ed look at the camber and the offset in the wheels
