Hi all, FES will be at AMVIV again this year. So if you want one of our products, just let me know and I'll reserve one for you! This is a good idea, especially if you want one of the InvisiLens kits. We'll also have the new InvisiLens R56 Speedo! Also, let me know if you want an item installed. I should be able to block some time for that. Control Modules: Ian Cull Auto-Up v7.1 (even smaller than before) Top Commander for R52. Auto Sportplus for 2nd gen new MINIs (including JCW) InvisiLens Kits For all 1st Gen and 2nd Gen Configurations. Please let me know what configuration you want. Bavarian Technic Diagnostics Software Enthusiast Version (3 vin limit) Pro Version (supports coding!) TrackCoach(tm) ProShift Shift Lights New Molded Cabling I/O with digital outputs Street Version (no outputs) High Current Relay Modules 2 and 4 Channel Versions For controlling higher current accessories. Works with ProShift I/O Works with SteathMode Accessory Control in the Ian Cull v7.1 and the Auto Sportplus NEW High Performance Valve Springs ~25% stiffer than stock. Great for high revving engines. Great for aftermarket cams. Respond in this thread if you want me to reserve something for you. See you in Vegas! Matt
So far I have... Kelly Girl InvisiLens 1st Gen Standard InvisiLens 1st Gen Nav Jerry InvisiLens 1st Gen Chrono ProShift Street Rooster Ian Cull Auto-Up v7.1 Top Commander for R52 InvisiLens 1st Gen Standard CFMINI InvisiLens 1st Gen Standard TrackCoach(tm) ProShift (Not sure version) High Current Relay Module (maybe) Any more? Matt
Any more requests? I've got another engagment at the beginning of next week, so will be packing up stuff over the weekend. Let me know if you have a specific request so I can make sure I have it for you! Matt
