1st Gen R53 Cooper S Finally found something I am annoyed by on my R53
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Pac10sux, Feb 3, 2015.
  1. Pac10sux
    Pac10sux New Member
    Jan 31, 2015
    17
    3 things actually:
    1 DSC. What the Hell MINI. It is worse than being sixteen and learning to drive with an overbearing mother!
    2 no auto roll up. Cmon, I think my 2000 MRS came with auto roll up and the convertable top was manual! Worst yet, the windows roll up like they are turtle driven.
    3 the stupid trunk unlock. Unlocking the car doesn't unlock the trunk, that requires a separate button, but does it pop the trunk open? Nope. What a useless button (although the key would look weird without a button there.
  2. minintrigue
    minintrigue Active Member
    Sep 30, 2009
    233
    Banker
    Cincinnati, OH
    Agree on #1.
    #2 can be addressed by using Isn't auto up circuit. I love mine.
    #3. Can't say it ever bothered me.
  3. TheModFather
    #1 Has an "OFF" switch...
    #2 Is a bit of a pain...
    #3 Cant be helped...
    But #1 and #2 can be solved with either coding with NCS or the Ian Cull circuit board stuff. ;)
  4. rkw
    rkw Well-Known Member
    443
    What year is your R53? It was a programmable option at least in 2005+. Unlock button on my key is set to unlock everything on the first click (trunk and both doors).
  5. Dave.0
    #5 Dave.0, Feb 3, 2015
    Most cars have a seperate pull or button for the trunk now even on the remote.
    1 & 2 is an easy fix as stated above with this http://www.fes-auto.com/products_detail.php?productid=35
    or you can have them "coded" in to your R53.
    * when I say "coded" I do not mean the at the Dealership because they do not have the access to do it because they are also locked down.
    You have to have some like Mike at Helix code it in for the R53's with a "program" he has and he can access everything and ALL the options.
    Mike coded my windows to go up and Sunroof to close with my OEM remote.
  6. ZippyNH
    If you get your car tuned, the DSC can be made less aggressive at the same time....
    And an auto up module is the best first mod IMO...also has the "track mode" setting for the DSC...
    I solved the DSC problem by ordering my MINI without that nanny. You kill her with auto-up with track mode.
    Solved the traction nanny issue by killing her with an auto-up with track mode.
    No truncated problems with the trunk.
  8. MCS02
    There is one more thing that annoys me about the R53!
    #4 no other car is as fun to drive as the sweet sounding super charged R53!!!:D
  9. mrntd
    Added the auto up module for 1 and 2
    My unlock unlocks everything. If I hold it the windows go down and the sunroof opens.
    Have it do the reverse on locking might be worth the reprogramming this year.
  10. fridayxiii
    fridayxiii Member
    Mar 7, 2013
    86
    49
    Tampa Bay, FL
    Dave, do you know if Helix can code both windows to go up, one-touch? Last year at MOTD I stopped by their tent, and they said it was passenger side window only. I was planning to stop by this year and at least have that done, but it'd be ideal to give both windows one-touch (if possible). Oh yeah, I have a 2006 R53. :cornut:
  11. Dave.0
    Yeah Mike @ Helix (Blue Mohawk) can do that. It's a quick double tap for up just like the quick double tap for down.
    The cool part is you will also be able to open and close all your windows & sunroof with the remote. You tap once to lock and unlock if you tap and hold down the lock button it will roll up the windows and close the sunroof also.
    Just like it does from the factory when you tap to unlock then hold the unlock bottom down for rolling them down and open the Sunroof.
  12. fridayxiii
    fridayxiii Member
    Mar 7, 2013
    86
    49
    Tampa Bay, FL
    Thanks Dave, much appreciated!! :Thumbsup:
  13. Dave.0
    Your user ID is coming up next Friday. :cornut:
  14. FranticFreddy
    FranticFreddy Drive-N-Eat
    325
    Some Where between here and there.
    There is this one feature I hate on my 2005 R53, The odometer keeps moving while I am driving.
    I HATE that!!!!:cryin:
  15. fridayxiii
    fridayxiii Member
    Mar 7, 2013
    86
    49
    Tampa Bay, FL
    Hot Damn, it sure is!!! :cornut: Whenever that day & date come together, it's my time to run amok, wreak havoc, and terrorize the villagers even moreso than usual :devil:
