First MINI and need help
Discussion in 'Starting Line - New Member Introductions' started by jeremyh, May 26, 2015.
  1. jeremyh
    jeremyh New Member
    May 25, 2015
    commercial diver
    florida
    Hello my name is jeremy and I bought my first r53 about a month ago and 3 days later spun a bearing I put a used motor in it and got it running the problem is it runs for about 10 mins and then the eml light comes on and them dies if I wait a few mins it will start right back up then do it again I haven't put the heart sheilds back on yet and wandering if maybe that is the problem Amy help would be greatly appreciated
    Check the crank pulley. If original it could be splitting. Thats my idea to start.
    Oh, and your battery, how old is the battery. MINIs hate low voltage, they get weird.
  3. amit
    amit New Member
    Mar 4, 2015
    21
    6
    Driver [Motor-er]
    Old Line State, USA
    Nathan, i heard its not recommended to give someone a jump with your mini, is this related to the voltage you mention earlier?
    Is there a heuristic i should follow or just straight up not do it? Also, what about using this jumper packs to jump your car in the event your battery dies?
  4. mrntd
    Welcome Aboard!
  5. MCS02
    6,278
    Welcome to MA!
  6. MCS02
    6,278
    I have jumped several cars with my Mini. With any modern car you can blow the voltage regulator. Just make sure your motor is turned off and you hook the cables up correctly. Try to use a ground that is away from the battery when able. I have seen a battery explode when some was trying to jump a car. That was fun!
    All that being said all new cars Mini included have a lot of electronic parts, they do not like spikes in power.
  7. Zapski
    Welcome! Enjoy the ride!
  8. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    You can jump MINIs, or give a jump from your MINI, if you do it correctly. OP, the first step is to get a scan on your car. Where are you located?
  9. jeremyh
    jeremyh New Member
    May 25, 2015
    commercial diver
    florida
    New battery and is there a difference between the 2003 motor and the 2005 luckily I have 2 sensors for everything
