First timer
Discussion in 'Starting Line - New Member Introductions' started by hamybone, Mar 30, 2016.
  1. hamybone
    hamybone New Member
    Mar 29, 2016
    Maryland
    HI! I have a 06 mini cooper S conv. Last week it it shut off on me . Wouldn't start back up . Wasn't getting gas I thought it was the fuel pump , I hot wired it and it works . Checked all fuses and put a different fuse box in it. Still won't start . If I jump out the fuel pump car starts and runs fine . I need some help Thanks
  2. 00Mini
    2,275
    Welcome to Motoring Alliance!! I personally do not have an answer for you but someone will come along and most likely ask some questions to better help you. If'n you are going to work on your car yourself then acquiring a Bentley manual will prove to be a very helpful tool.
  4. Dave.0
    Welcome to MA
  5. Goldsmithy
    Jan 30, 2015
    1,748
    982
    TCB
    Main Street in the land of Oz
    Welcome to the modness. I am relatively new here, but have any mods been done to your car? How many miles? Maintenance records? Any lights or codes?
  6. hamybone
    hamybone New Member
    Mar 29, 2016
    Maryland
    It has 86000 miles on it . The codes i got were p0420,p0445, p0031,p0037 ,p0340 . was thinking most were from running with no converter . Thanks
  7. MCS02
    6,328
    Welcome to MA! Possible a relay have you checked it?
  8. hamybone
    hamybone New Member
    Mar 29, 2016
    Maryland
    I have checked main relay under the hood and replaced the whole fuse panel by the kick panel . the fuel relay on the fuse box panel is not removable that's why I replaced it. Am getting power to the relay but not getting the signal from EMS to pull relay in.
  9. wmwny
    4,040
    2,242
    Welcome to M/A!
