Suspension Brakes Fitment of Strut Brace and Intake Combo Reference 2ND Gen MINI
Discussion in 'Tuning and Performance' started by Way Motor Works, Mar 13, 2012.
  1. Way Motor Works
    Way Motor Works New Member
    206
    MINI Tuner
    Atlanta
    Many people ask me if XXXX strut brace will work with XXXX intake. So I thought I'd start a reference thread for people that are using an aftermarket strut tower brace and aftermarket intake together.
    So please post:
    Which brand/style strut tower brace your using?
    Which brand/style intake you have?
    and any issues with the combo or not?
    I think this could be very helpful for people looking to do a certain combo to know if it will work before they buy.[​IMG]
  2. davavd
    davavd Club Coordinator
    6
    Architect
    Covington, La
    Great idea! In the R52/R53 column, JCW strut brace works with a Promini intake.
  3. minimark
    R53 with JCW intake and strut brace.
  4. Mr. Jim
    Same here and also the OMP works with JCW intake.
  5. BThayer23
    R53 with M7 brace and Alta intake, fits fine.
  6. agranger
    On an R53, the M7 strut brace works fine with the DDM Intake
  7. Firebro17
    M7 strut brace with the JCW intake works well. I would prefer to use the JCW strut brace but the previous owner cut out the shock towers to accommodate a set of camber plates. Thus, my need for a full plate on top of the shock tower...
  8. jiminni
    jiminni Well-Known Member
    262
    Ca.
    03 MCS: M7 strut brace with Alta/with top. Rubs the top just a tinch, good thing about it, keeps the top on snug. Plus I removed the "Chewbacca" mat under the hood :lol:
  9. Jason Montague
    :cornut: 08 R56 MCS/JCWm. JCW strut brace and Alta CAI, working great.:Thumbsup:
  10. Way Motor Works
    206
    MINI Tuner
    Atlanta
    Hey guys this is the second Gen section R55 R56 R57 R58 R59, that's the info we are looking for not R53 info.
  11. Mr. Jim
    Oops :) didn't see that in tap-a-talk
  12. Redbeard
    1,636
    398
    Glorified spreadsheet jockey.
    Given the way the Defenders of Speed (DoS) Intake sits I would assume it's out of the way of most any strut-brace.
  13. Nathan
    Adjusted the thread title to reflect this a 2nd gen thread.
  14. greydave
    greydave New Member
    Oct 18, 2011
    Tequesta,Fl.
    11 R55 MCS nm strut brace bar contacts stock air box flange,had to make shims.
  15. Firebro17
    Glad'ta see there's more than just me that can't comprehend... So Sorry.
  16. Way Motor Works
    206
    MINI Tuner
    Atlanta
    Might check to make sure you have the later NM bar, the earlier bars where slightly shorter. NM changed them all to make em fit.
  17. ScottinBend
    Might want to migrate the OT posts to the other thread?
  18. Nathan
    Due to the time stamp on them it would make them appear before the thread even started. Talk about a mess...
  19. ScottinBend
    What......you don't have a (black) hole in your pocket you could use......:biggrin5:
    Sorry, back on topic now!
  20. old81
    M7 Strut Bar with DDM Steet Intake requires you to trim the DDM box on the 07 MCS.
