Flat top jack stand
Discussion in 'MINI' started by ScottinBend, Jan 5, 2010.
  1. ScottinBend
    I am trying to find a replacement for my conventional saddle jack stands with something a bit more stable and less damaging.
    I am open to suggestions for some flat top stands or even a different jack point set-up like the TSW aluminum ones or something similar.
  2. goaljnky
    3,105
    394
    Stop being a wuss. Just use some bricks and 2x4 pieces.
  3. ScottinBend
    :prrr:
    I thought the whole ghetto thing left with Lynn.................:yikes:
  5. Mike
    Mike New Member
    Wow, they have a heck of a good selection of floor jacks, too!
  6. PGT
    PGT Wheel Whore
    Federal Gov Contracting
    Leesburg VA
    I've had these Torin's....$70/pr at Northerntool.com
  7. Motoring Magic
    Motoring Magic New Member
    397
    266
    Thousand Oaks, Vta cty, socal
    Those AC Hydraulic stands were on my long list for a few years...guess the ASE/ESCOs take their place. Still can't justify replacing the ones I have though (the Torins mentioned by PGT...though mine came free with a jack) just to make things work a little easier.
  9. Nathan
    I have those Torins as well and have been quite happy with them.
  10. agranger
    1,486
    I thought that I have also seen, somewhere (probably an ad in Roundel), a converter that fits in to the rectangular jackpoint for BMWs (same as ours) and presents a flat disk for a floor jack or jackstand.
    That would be great. I cut four rectangular pieces of oak that fit snugly up inside the jackpoints and extend a bit below the plastic edge to sit on the flat part of the top of the Torin stands.
  12. Minidave
    4,594
    And in fact, didn't the GP's come with these in the tool kit? I'll bet either you can get them from MINI or from someone who sells Mini/MINI parts....
  13. Rickomatic
    Rickomatic New Member
    Oct 28, 2009
    I did the same, plus I temporarily tape them on with some masking tape. This makes the stands fit better without messing up the plastic parts.
  14. Rixter
    Rixter Well-Known Member
    Jun 14, 2009
    1,230
    79
    Technology Architect
    North of the 49th
    I'm going to be getting myself a set, should I be looking for flat top stands for the MINI, versus any other particular top?
  15. Nathan
  16. PGT
    PGT Wheel Whore
    Leesburg VA
    I believe Eastwood sells them too (body shop supply company)
  17. Rixter
    Jun 14, 2009
    1,230
    79
    North of the 49th
    Again, why does it matter what shape the top of the floor jack stand looks like? Is it for stability or avoidance of damage?
    With a flat top -- esp. with a rubber pad like those ASE/ESCOs -- you have the best and most stable distribution of weight across the base of those plastic jackpoints under your MINI. Most jack stands I've seen have some sort of saddle shape that makes it a challenge to get the car sitting evenly on them, and the contact area isn't large enough to distribute the weight evenly. If you don't get them oriented just right you risk damage to the plastic bits and/or instability.
  19. Rixter
    Jun 14, 2009
    1,230
    79
    North of the 49th
    Thanks for the explaination Steve. That helps a lot.
    I just read a post on an E90 forum saying use a hockey puck...not a terrible idea...
