2nd Gen R60 Countryman Fog Light Bulb Upgrade
Discussion in '2nd Generation: 2007+ R55 through R61' started by Mini Q, Oct 28, 2014.
  1. Mini Q
    Mini Q Member
    Nov 11, 2010
    46
    Fullerton, CA
    Any suggestions for upgrading the bulbs to brighter ones that will not trip the "bulb out" indicator?
    Brighter in a fog light is kind of counter productive if you want the light to function as a fog light. Brighter bulbs should not give you any bulb out warnings. LED bulbs will, because there is not enough current draw from them.
  3. Dave.0
    Get an 35 W HID fog light kit ONLY. (Not 55 W kit) $29.99 :Thumbsup:
    A 55W kit will get too hot for the plastic housing but your lens will be ok because its glass. not worth the issues. Just stick with the 35w.
    I have them and they have worked great for years. The kits are well made with waterproof connectors and sealed digital ultra-thin ballasts. (Easy plug and play)
    The fog bulb size is : H11 for an R53
    DDM Tuning 35W and 55W HID Kits
    I do not use them as fog lights, I use them as driving lights.
  4. Mini Q
    Mini Q Member
    Nov 11, 2010
    46
    Fullerton, CA
    Thanks for the suggestions. I put LED bulbs in my Clubman and right away got the bulb out.
    I would like to use the fogs as driving lights.
  5. Dave.0
    See my post above. :Thumbsup:
  6. Metalman
    You need to get the LED's that have a "load" resistor built into the circuit so the MINI thinks the bulb is still good.....
  7. Mini Q
    Mini Q Member
    Nov 11, 2010
    46
    Fullerton, CA
    any idea who makes the LEDs with the resistor?
  8. Metalman
  9. Mini Q
    Mini Q Member
    Nov 11, 2010
    46
    Fullerton, CA
    Thanks Metalman
  10. Dave.0
    LEDs won't provide great light output.
  11. ScottinBend
    LED's suck at driving lights......
    Putting a brighter bulb into a fog light will not change it into a driving light. The reflector & lens are what determines fog vs driving. You will have a brighter fog light that no longer works well as a fog light & doesn't work as a driving light.
  13. vetsvette
