Foot Clearance
Discussion in 'MINI' started by patchelect, Nov 27, 2013.
  1. patchelect
    patchelect New Member
    Oct 25, 2013
    98
    31
    Currently still working in electric motors sales a
    Patchogue, NY/Dalton Ma
    I wonder if I'm the only one with the problem of fitting my right foot in the narrow space allotted between the tunnel and the brake pedal? I haven't had the car very long but I have noticed that it seems that if I'm not careful I hit the brake pedal when I try to put my foot on the gas pedal. I don't have the problem in sneakers, but a pair of hard soled shoes causes difficulty. I haven't seen any "fix" but I assume others have the same problem since my canal boats are only size 10. What do people with size 12+ do? Is there a suggested correction method?
  2. Zapski
    No problem here in my size 13 feet.
    I know this problem all to well. I can't drive my MINI anything but moccasins. Anything else I wear on these wide feet get caught up in the pedals.
    It's not that big of a deal for me as I tend to wear moccasins pretty much all the time anyways. But with snow flying and the need to keep the feet dry and warm it becomes a bit of a challenge. I tend to carry a pair of sensible shoes this time of year and do a wardrobe change as needed to drive.
    I also changed the pedals to give me a bit more room. I used ones from Custom Aluminum Vehicle Pedals - ULTIMATE PEDALS. The bake and clutch pedals are from a Ferrari.
    Not the best image, but will give you an idea of what I did.
  4. ScottinBend
    I too just have a set of "driving" shoes I wear. If needed I just put a different pair in the boot and change shoes at my destination.
  5. patchelect
    Oct 25, 2013
    98
    31
    Looks good. I had something like that on my Miata but mostly because the rubber bits had gone away.
    I guess I'll adapt as everyone else seems to.
    I have the same problem. It's all about the width. I need a shoe with a wide forefoot so I have to choose shoes based on which car I'm driving. In the MINI, I can't wear boots or anything with a sole wider than the rest of the shoe.
  7. pmsummer
    pmsummer Well-Known Member
    Apr 3, 2012
    570
    400
    Semi-retired planner
    I have to remember to wear narrower-soled shoes when I drive the MINI... especially if I plan on driving 'spiritedly'.
  8. beken
    beken Well-Known Member
    Jan 13, 2010
    1,405
    1,829
    Delta, BC
    #8 beken, Nov 28, 2013
    I usually had that problem when wearing my steel toe work boots and having to drive from site to site for work.
    Thought I would add a picture of one of the places I worked....
  9. Zapski
    Must be an R53 thing. I wear heavy boots all the time.
    *shrugs*
    Never had a problem with my R53 or any R56 I have driven. Although I never drive in boots.
  11. GokartPilot
    GokartPilot Well-Known Member
    Jan 9, 2012
    967
    727
    training specialist
    Maysville, North Carolina USA
    I just installed the Rennline Pedals and I am running into the same problem on every pedal. I bought the accelerator extensions anticipating the need of assistance for H-T but that is not the case. I have modded my dead pedal platform, I have raised it to a more comfortable position, now I am hitting the side on occasion when I release the clutch. I am thinking I might have to mod that pedal a little more to fix that problem.
    Anyone in need of the top extension for the Rennline pedal?
  12. CHKMINI
    I have wide feet and have no problems with my Rennline pedals. Yes, they are close, especially the brake-accelerator but I like the ease of rolling the throttle on downshifts. I mounted the dead pedal directly to the factory platform as outlined in their directions and have no clearance issues. Sorry you're having problems....great product!
  13. GokartPilot
    Jan 9, 2012
    967
    727
    training specialist
    I like the pedals, I think it is something that is just going to take a little getting use to. I have raised my dead pedal almost even with the clutch pedal, I kind of like just rolling of the DP on to the clutch and back, its easier on my knee.
  14. patchelect
    Oct 25, 2013
    98
    31
    Having owned the car for a few months I will report that my initial trepidation has gone. I either figured out how to drive the car with my work boots or was worrying about it too much in the beginning.
    ^^^ It is just a thing that will take time getting used to. After a while you won't notice a thing once your muscle memory kicks in. Love those Renline peddles!
    Full disclosure: My MINI doesn't have peddle enhancements & I use the sycros my box of cogs came with. :wink:
    :postcount
