2nd Gen R56 Cooper S Forge atmospheric BOV issue. Lost power, poor idle.
Discussion in '2nd Generation: 2007+ R55 through R61' started by photoputz83, May 6, 2015.
  1. photoputz83
    photoputz83 New Member
    Apr 18, 2013
    9
    So I decided to buy a forge blow off valve for my 2010 mini s. I installed the valve and made sure all connections are correct, and that all sensor are seated properly. Knowing that I installed it correctly I figured it should work fine and would have a fun drive around town. Not the case. I lost quite a bit of power, it sound like the valve is open at light acceleration, and at idle it hesitates to stay running. Does anyone have experience with this, or have any ideas?
    First thing I'd do is put the old one back on and validate all is normal. If so, you may have either missed something on the install or it is possible the unit is faulty.
  3. photoputz83
    Apr 18, 2013
    9
    Could it be caused by a weaker spring on the bov?
  4. photoputz83
    Apr 18, 2013
    9
    It was fine before I pulled the recirculation valve. I have no codes, and torque pro shows that my parameters are in the green.
  5. Jason Montague
    :cornut: Bump Bump. I don't have the answer but now you're back at the top of the list.:Thumbsup:
  6. photoputz83
    Apr 18, 2013
    9
    So I pulled off the intake, inspected all the vacuum hoses, looked at the instalation instructions, checked all the bolts for tightness. Everything is in the green. Ran torque 2 pro, and used my snap on solus diagnostic setup.....still no indication why this is happening. Manifold pressure across the board looks good, and still not pulling any codes. motor has 53k on it, and valves were blasted 4k ago. Nothing seems to be throwing a red flag besides the lack of power. From my torque 2 app I'm only showing 7 psi max. On Monday I was pushing 17-18. I installed the heavier spring and I'm not seeing any change.
  7. Dave.0
    Put the old one back on the car and retest it. The problem looks to be the Forge unit.
    Don't believe the computers listen to your car, it's not working right.
  8. ColinGreene
    ColinGreene Well-Known Member
    438
    293
    Orange county Ca
    The car has the same problem subarus do when you do this, its looking for the recirc air and its not seeing it.
    try going back to stock to see if that solves the problem.
    If it does id imagine this will be up for sale soon.
  9. wzabrouski
    wzabrouski Active Member
    32
    Executive Director
    Keller, TX
    I had a similar issue with the atmospheric valve. It's looking for the missing air. Put the recirc one on with no issues. Upgraded the turbo and stayed with stock. The stock valves work fine unless they rip but they are as good as any other.
  10. photoputz83
    Apr 18, 2013
    9
    So the issue ended up being the o ring supplied from forge. The o ring diameter wasnt substantial enough for it to create a seal against the seating surface of the turbocharger. Contacted forge with the issue and they are looking into it. Went to a local parts store and picked up a couple o rings. Works perfectly now. lag is noticeably lessened with the bov. A slight improvement over the stock valve.
  11. photoputz83
    Apr 18, 2013
    9
    The snap on solus does live diagnostics. It did pick up some abnormalities, but nothing off to the point of throwing up a flag.
  12. Dave.0
    I know what Snap-on tools does and it very cool but it cannot detect everything as you found out bay taking off the part and finding the wrong O ring.
    Glad you got it fixed. :Thumbsup:
