2nd Gen R56 Cooper S Forge POV Sticking Open?
Discussion in '2nd Generation: 2007+ R55 through R61' started by Johngo, Dec 10, 2012.
  1. Johngo
    Johngo New Member
    1,671
    200
    Art Director
    Sugar Hill, GA
    I just installed a new Detroit Tuned Turbo Oil Feed Line and ran the car afterwards.
    Everything was fine. No codes. No fire. *WHEW!* :biggrin5:
    Under normal acceleration, it goes just fine, as usual.
    However, after a few minutes of driving and double checking no oil was pouring out from under the car, I got on it and it was going fine. First gear acelerates hard, and hear the POV when I let off, but once I hit it again in second it sounds like it keeps blowing off (we could hear it clearly) and power drops, like the turbo is not functioning.
    When I slow down, it functions again. But if I accelerate hard, it does the same thing.
    Anyone have an issue with the Forge POV sticking open? Is the valve bad? Sticking? Broken spring?
    And as a side note, I photographed the entire DT oil line install and will be putting a tutorial together. It is an involved job, but not impossible. :Thumbsup:
  2. grodenglaive
    grodenglaive New Member
    Apr 3, 2010
    313
    68
    Ottawa, Ontario
    I had the same symptoms after installing a boost gauge, but it was just a bad seal on the boost tap. You have a leak somewhere, maybe the BOV, but more likely you jarred something loose when doing the oil line.
  3. Johngo
    Johngo New Member
    1,671
    200
    Art Director
    Sugar Hill, GA
    Didn't touch anything on that side... You thinking a vacuum line or something?
  4. Dave.0
    Good luck with fixing this.
    I just misread the title and thought it said Forge POS ......:lol::lol::lol:
  5. countryboyshane
    countryboyshane New Member
    Jul 23, 2009
    202
    Diesel Engineering
    Bloomfield Hills, MI
    POV? What?
    Do you have this diverter valve?
    Forge Motorsport | Alloy Fabrication
    If not check the OEM diverter valve for cracking.
    If you have the Forge diverter valve, make sure you didn't loosen or accidentally cut all the vacuum lines going to that component. When I installed mine, I used some extra 90 degree vacuum line fittings to decrease the amount of bends the rubber vacuum pipe had. Those lines can kink easily if you're not careful.
    Another easy thing to mess up when you're messin' around the turbo is the vacuum line to the wastegate.
    Might as well tighten all the hose clams in the air system while you're at it. They loosen over time.
  6. k-huevo
    k-huevo Club Coordinator
    159
    Pipe Creek, Texas
    How many nipples does your Forge unit have? If only one, return for an upgrade. Remove the end cap and make sure the O-ring is intact and where it is supposed to be. Remove the piston, be sure there is a little lube on its O-ring. When screwing the cap back on, make sure it is very tight.
  7. Johngo
    Johngo New Member
    1,671
    200
    Art Director
    Sugar Hill, GA
    Thanks all.
    I think it is the original. I haven't seen it, yet as it is buried under a bunch of stuff... But I know it was one of the first ones Way installed. Been great so far, but now that you say that, I think I recall him saying there was a replacement out for the originals.
  8. k-huevo
    159
    Pipe Creek, Texas
    Become familiar with accessing the valve because it will require lubrication maintenance, and an occasional twist of the cap lock ring.
  9. Johngo
    Johngo New Member
    1,671
    200
    Art Director
    Sugar Hill, GA
    Good to know... I will check it tonight. Thanks, K!
