Way Motor Works has FREE SHIPPING this week on the CG Locks for your MINI seat belts. If you're looking for the most cost effective driver and passenger restraint system this is it. And you you have a MINI Roadster, Coupe, or Countryman that can't use the Schroth harnesses this will be your best alternative. The CG Lock can be installed in just minutes and disabled in seconds if you don't want to use it. The CG Lock simply attaches to the end of the seat belt and when you lock it down it will hold the lap belt tight while allowing normal movement of the shoulder belt. This will hold you in your seat tighter when running the twisty roads like the dragon, or AutoX and even Track Days. There is no special promo code or extra work on your part to get the FREE SHIPPING, just go to the site add the CG Lock to your shopping cart and check out no shipping will be added.
