For the front lower control arm I thought I saw a different mounting bracket for the bushing to go into the changed the geometry some to reduce squat and dive. I found the one I used on my WRX so maybe I'm confusing the two. Does anyone know of such a product?
You Alta not use these. I have read many times how folks buy these & end up removing them due their poor quality. Lightens your wallet making you faster so that's something.
Hey now.......I have had those installed on my car for almost 10 yrs with no issues except for some rattle when very cold. Problem they had was that Alta refused to use a decent set screw to hold the arm in place. It would work loose and cause a lot of rattling. Work around was to tack weld the arm onto the bushing sleeve. That is what I had done and so far no problems.
Nice design when one has to weld it together to make it right. Glad it works for you. Maybe the other folks weren't willing to weld the thing up for some reason or another?
