Exterior 1st Gen Front splitter diy
Discussion in 'Tuning and Performance' started by Tummi_Gummi, Jul 27, 2014.
  1. Tummi_Gummi
    Tummi_Gummi New Member
    Nov 19, 2012
    384
    103
    Online Sales Manager
    Springfield, MO
    Yup I am at it again. With the successful diffuser build I am ready to tackle the front end. I could not find any information on the front tires sticking out past the bumper and what affect it has on aerodynamics. I always wondered if it would be best to have the flat splitter (horizontal) run out past the ends of the bumper to align to the edge of the tires and then bend a piece of metal to match the curvature of the front fender trim to cover the exposed tire. Would this be practical? Would it be best with a few slit vents angled more aggressively? Also do any small upper splitter wings matter on the bumper near the turn signals? To angle air up over the tire?
  2. mrntd
    A tire sticking out into the airflow will hurt the flow around the side of the car. It make turbulence and drag. Even in open wheel racing you will see the front wing and floor shaped to divert air around the tire.
    So having flip-ups at the end of the splitter to help air up and around the tire is a good idea. It probably won't do anything for downforce but it will help for drag.
    The corner winglets help with downforce on a race car. But adding them to the MINI is just for looks. They are only stuck on with double sticky tape in most cases so how much can they really do.
    While your at it consider skirting the sides. I've done this in the past and it's on the list for my MINI. I've used conveyor belt material and vinyl waynescoating before.
  3. mrntd
    I searched for your diffuser info and didn't find it. Can you share it?
  4. Tummi_Gummi
    Nov 19, 2012
    384
    103
    Springfield, MO
  5. MCS02
    Looks good.
  6. Tummi_Gummi
    Nov 19, 2012
    384
    103
    Springfield, MO
    I am having trouble getting the piece of aluminum to my shop. Won't fit in my mini. Ah good times
  7. Alan
    Alan Active Member
    98
    New Braunfels, Texas
    I made these side deflectors. It's a sneed speed splitter.
  8. cct1
    That looks like it would be very effective, be cool if you could blow smoke over it before and after just to get an eyeball test of what it's doing. My wheels stick out to high heaven (9 inch wide on the front), and eventually I'll probably do RMW's wide body kit.
  9. N2MINI
    N2MINI MINI of the Month
    Dec 4, 2009
    3,349
    575
    Sign Maker
    Looks to be affective. Did you try one with the bottom edge inline with the splitter so that it then has a cleaner "looking" edge at the bottom and angles out to your top point. Looks wise, it wouldn't look as squared off.. but who cares about looks on a race car right!!!
  10. mrntd
    Alan what material did you make the spliter from?
  11. mrntd
    Tummi_Gummi, did you change to a straight exhaust or stay with the standard layout? Happen to have a rear shot?
  12. Alan
    Alan Active Member
    98
    The splitter I bought from Sneed Speed. I did make my own mounting brackets for it so it is right up against the sub-frame.
    The side deflectors are 20 or 22 gauge steel sheet - can't remember which off hand. Available at Home Depot & Lowes. I wanted something thick enough to not distort in the wind, but thin enough to cut and work. I bent the outside edges over for extra rigidity and so there are no sharp edges.
  13. Belhaven
    Belhaven Active Member
    Jun 2, 2009
    109
    40
    I read "front splitter DIY" and I see TopGear plywood splitter in flames :)
  14. mrntd
    Thanks for the the info.
  15. Tummi_Gummi
    Nov 19, 2012
    384
    103
    Springfield, MO
    Stand r53 it Y's around the battery box. The middle horizontal piece of the diffuser lines up with the box.[​IMG]
  16. Tummi_Gummi
    Nov 19, 2012
    384
    103
    Springfield, MO
    [​IMG][​IMG]
  17. mrntd
    Thanks for the shots. Now I need to get my measuring tape, a pencil, and some paper. :Thumbsup:
  18. Tummi_Gummi
    Nov 19, 2012
    384
    103
    Springfield, MO
    These should help anyone looking to copy. The rear flaps really seal in the deal. I also made a 1" slightly curved piece of aluminum for mounting the diffuser to the bumper trim to support the plastic, at first I though huge washers could distribute the weight but I was wrong. So the strips of aluminum had matching cat holes and acted as a sandwhich to keep the trim flat and weight distribution even.
  19. mrntd
    Thanks a lot. I'll get to work now.
  20. Tummi_Gummi
    Nov 19, 2012
    384
    103
    Springfield, MO
    The key is the middle piece because it is at an angle. And is a key component to have straight and even. So I used a flat edge of a fresh cut aluminum sheet for it. My cutoff wheel could cut straight enough and I didn't want to try to grind it either. It's 13" on the outside flat piece and 10" wide on the inside piece. That inch and a half wider end on both sides gives the diffuser the right amount of angle. I think the dams on both sides were square 15" then I had to custom cut it to fit around my mufflers. And the vertical pieces were something like 5 1/2 and 4 1/2" that way They were the same because the rear bumper curves upward as it goes towards the outsides. The 5 1/2 go on the outside
