FS: 2007 MINI Cooper S
Discussion in 'Classic Mini, MINI and other Cars for Sale' started by boosted_r56, Mar 7, 2013.
  1. boosted_r56
    boosted_r56 New Member
    May 9, 2011
    29
    I am selling my MINI cause I am ready to dump all my money into my E30. RWD has taken over me.
    So for sale we have my 2007 R56 MCS:
    Mileage: 105k (Yes its high but its a drivers car)
    Packages: Sport, Cold Weather, Premium, Sunroof
    Color: Dark Silver
    Trans: JCW 6 Speed Swap ($3900)
    Diff: Quaife LSD ($1100)
    Engine: Compression test came back solid
    Tune: RMW Dyno Tune ($610) - 225WHP/250WTQ
    Suspension: JIC-Cross Coilovers ($2400)
    Intake: Stock Airbox + K&N Drop in, Alta Turbo Inlet Pipe
    Intercooler: Alta FMIC ($700)
    Downpipe: Catless Riss Racing DP ($200)
    Catback: Magnaflow CB ($250)
    Turbo: Stock K03 (Will come with an uninstalled hybrid K04) ($650)
    Wheels: ESM-001 17x8 +35 ($900)
    Tires: 90% (4) Kumho Ecsta AST ($400)
    Windows: 20% Front, 5% Rear, Windshield tint strip
    Antenna: Alta Stubby
    Clutch: Spec Stage 1 ($600)
    Brakes: Stoptech D/S Rotors, Stoptech Street Performance pads, SS Brake Lines (4)
    Shift Knob: JCW CF Knob
    Piping: Alta Hot side, NM Engineering Post FMIC tube
    DV: Alta Stiffer Spring
    Grille: JCW Grille
    Scuttles: Areo Gen2 Scuttles
    Recent Maintenance:
    New OEM Transmission mount
    New OEM Wiring Harness
    New OEM Flywheel
    New OEM Cam Pos Sensor
    New OEM Crank Pos Sensor
    New OEM Rear Pads/Rotors (6k miles)
    New OEM Driver side Hub/Bearing
    New OEM Tie rods (inner/outer)
    New OEM 02 sensors x 2
    New OEM DV
    Known R56 Issues that have been serviced:
    Water Pump replaced (60k Miles) OEM Unit used
    HPFP Replaced (65K Miles) Dealer done
    Thermostat Housing replacement (70k Miles) OEM Unit Used
    Timing Chain Tensioner Replaced (Every 20k Miles from 50k - 105K)
    Car is higher mileage but has all the service and maintenance to back it. Transmission was just swapped for a new OEM JCW trans after my S 6 speed failed on me. At that time I had the Cam and Crank sensors done along with a new flywheel, spec clutch and quaife LSD. Looking to start putting my money into my e30 now.
    Below are some pics of the car, feel free to email or pm me for more info.
    Email: jaycheetwood at gmail.com
    Asking $13,500.
  2. Jason Montague
    :cornut: GOOD LUCK!:Thumbsup:
  3. boosted_r56
    May 9, 2011
    29
