1st Gen R53 Cooper S Fuel Feed Line?
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by GeorgeCo, Jan 26, 2014.
  1. GeorgeCo
    GeorgeCo Site Sponsor
    Motoring Alliance Sponsor Supporting Member
    Oct 29, 2009
    253
    38
    Motorer
    Mt. Airy, MD
    Looking under the passenger side of my 2006 R53 while I changed the oil yesterday, I noticed one of these three lines was crushed. The crushed one is the fuel feed line, no? How hard to repair?
  2. GeorgeCo
    Oct 29, 2009
    253
    38
    Motorer
    Mt. Airy, MD
    If anyone is wondering, the line is only a$75 part, but you have to lower the subframe to fit it.
  3. Dave.0
    Wow that sucks but at least the part is not really expensive.
  4. MCS02
    The only thing I know to do is replace the line. Lowering the subframe is a lot of work but it's not hard. Good luck!
  5. Jason Montague
    :cornut: Yup. Time to break out the 'Bentley Manual' for the absolute best instruction on how to do this correctly the first time and what tools to have on hand. Good luck.:Thumbsup:
  6. Systemlord
    Systemlord New Member
    Mar 28, 2013
    311
    67
    That one line looks completely crushed to where nothing gets through! :eek6:
  7. Dave.0
    Yup and jack points are your friends. :Thumbsup:
  8. GeorgeCo
    Oct 29, 2009
    253
    38
    Motorer
    Mt. Airy, MD
  9. Rawhyde
    Rawhyde Active Member
    Apr 7, 2012
    311
    233
    Facilities Engineer
    Mountains of NW Georgia
    I think Dave was pointing out that it's a good idea to use the proper lifting points when jacking a car. The damage to your fuel line appears to be from placing a floor jack in a bad place to lift the car.
    The first time I bought new tires for my MINI was at a Goodyear store in Chattanooga. I expected them to install the tires in a professional and safe manner. Luckily, I was right there to put a stop to the tech when he tried to lift my car by the plastic power steering fan. He followed up by trying to lift by the oil pan. (I didn't let him do that either.) Since that day, I leave the MINI at home and take wheels only to the tire store.
  10. GeorgeCo
    Oct 29, 2009
    253
    38
    Motorer
    Mt. Airy, MD
    Ah, I get it. No, that wasn't it. I hit a piece of schedule 40 cast iron pipe with endcap in the middle lane at about 40 MPH. Did this to my under-strut bar
    and sent me up on two wheels. You can also see the damage to the sub-frame in the picture at the top of the thread.
    Amazingly the alignment was OK.
    It was one of those split-second decisions you make when something drops in the lane in front of you and you realize there's no way you can get around an obstacle that you know is taller than your lowest point of ground clearance: 1. Hit it with the tire and sacrifice the tire/wheel; 2. Straddle it and risk puncturing the oil-pan; or try to get somewhere between the wheel and center line, hoping not to hit the control arm. Well I missed the control arm but hit on the sub-frame and under-strut bar. There was no way I would have cleared it even without the under-strut bar.
  11. GeorgeCo
    Oct 29, 2009
    253
    38
    Motorer
    Mt. Airy, MD
    I couldn't find it in the manual. Did you?
  12. Dave.0
    Holy crap! I thought some else had the car and when you got it you noticed that.
