Engine Drivetrain 1st Gen Cooper S Fuel Injector Cleaner
Discussion in 'Tuning and Performance' started by moreorless, May 11, 2011.
  1. moreorless
    moreorless New Member
    Aug 17, 2009
    343
    14
    In a pile of sawdust.
    What are you all recommending for a fuel injector cleaner?
    I'm at 57k miles.
    Is this something I should think about doing now?
    ...Les
    Les I run a bottle of Chevron Techron though all our cars just before every oil change. I pour it in the tank. FWIW I feel it is cheap insurance.
  3. BThayer23
    +1 on the Techron. I run a bottle when I clean the air filter, every 10k. Buy a bottle and toss it in the trunk, then next time you fill up, pour it in.
    Another Techron fan here. Whenever I have a drive planned that will use at a least a full tank and run a bottle of Techron through the system too. Like this Saturday when I drive up to Detroit for the Detroit Tuned Spring Clean Up Party.
  5. ScottinBend
    If you are using Chevron (or even 76) gasoline then you are already getting the benefits of just about a full bottle of the cleaner everytime you fill up the tank.
  6. Vollgas
    Vollgas New Member
    Dec 22, 2010
    157
    9
    Shell 93 and Chevron Techron user here!
    No facts, just feel it improves performance on my R50.
    39 mph on highway with no problem.
  7. ScottinBend
    Shell also has an excellent additive package. I wouldn't waste my money on anything additional if I were running Chevron/76/Shell.
    One mans wasted money is another's well spent money. Seems it is often on sale, when it is I stock up.
    No Chevron gas in Hooterville.
  9. BThayer23
    #9 BThayer23, May 12, 2011
    Yes, the additive packages in those gasolines are excellent. However, it helps to run a high concentration of detergent through the engine once in a while. It can clean out any stubborn build-up in the fuel system or injectors.
    Also, another benefit of Techron is the preservative effects it has on your fuel system. If you're going to store the car for a few weeks, put a bottle in a tank that's at least half full and run the car for a minute to distribute it through the fuel lines. (source: dvatp.com)
  10. Redbeard
    1,636
    398
    Glorified spreadsheet jockey.
    I'm old school. I drop the tank to 1/4 or less then dump a bottle of Berryman B-12 Chemtool Fuel Treatment (B-12 Chemtool MSDS) in the tank and run until I'm almost on fumes. Then fill up again and run down the road.
    The first three primary ingredients are: Tolulene, Acetone, and Methanol. With some Methyl-Ethyl Keytone (MEK) and other "evil" solvents thrown in for good measure. Berryman makes "friendlier" cleaner solutions. However, after using this stuff on FI Fords for years I have never seen a product work better. You'll know you have the right stuff because it's in a metal bottle. You won't find this stuff in a plastic one...
    The best part is that you can use a half can in your oil, run the car for 2-5 mins then shut-off and drain the oil. It will break down a ton of build-up oil in the crankcase.
  11. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    I had used Techron for years, recently tried the Lucas Oil product, thought it did a better job. Nothing concrete data wise, pure butt dyno
    Several years ago I asked a mechanic who was working on one of my Honda's and his recommendation was to use fuel injector cleaner every other oil change. Followed it ever since
  12. moreorless
    Aug 17, 2009
    343
    14
    This is good stuff gang.
    Thanks for all your replies.
    ....Les
  13. ScottinBend
    If you you are using the Chevron/76/Shell gas everytime, I really haven't seen any reason to run anything in addition to it. On my previous car after a tear down, there was virtually no build-up in the head or the fuel system and the car was run on Chevron premium exclusively, same as the MINI.
  14. Justa Jim
    I sure wish we had Chevron around here. :cryin:
  15. Redbeard
    1,636
    398
    Do you have Texaco? Same company.
