2nd Gen R56 Cooper S Gauge Sending Unit Replacement Part?
Discussion in '2nd Generation: 2007+ R55 through R61' started by MaverickGun, Feb 8, 2012.
  1. MaverickGun
    MaverickGun New Member
    Aug 24, 2011
    34
    Hey guys. I fairly recently had some gauges installed. Everything was looking fine, until one day I checked under the hood and found that one of the black screw on connectors that keep the wiring attached to the sending unit seems to have gotten lost somewhere. If I had to guess, it managed to unscrew itself while I was driving and is now off on some whirlwind adventure out in the great unknown. That's all well and good, but I'm not sure where I could find a replacement. Does anyone know exactly what I should be looking for? I attached a picture for the sake of clarity. Thanks.
    I'd sent a note to the company that makes the gauges and ask them for one.
  3. MaverickGun
    Aug 24, 2011
    34
    Thanks Nathan I'll look into that. They're Marshall gauges I bought from CravenSpeed. I wish there was a solution I could do locally, but in the event there isn't I'll give contacting Marshall a shot.
    Send a note to Kellen at Craven, or give him a ring. I'm sure he will help you get a new one.
  5. MaverickGun
    Aug 24, 2011
    34
    Maybe that'll be the easiest solution after all. Thanks again.
  6. Metalman
    Now here is the thing, those threads could be SAE or possibly metric, so you will need to verify the type of threads. Easy to do, take the one remaining screw to Lowe's and use their thread checker. They also have a pretty nice assortment of "Thumb Screws" so you may just luck out.
    If that doesn't work there is always McMaster-Carr......
    Go here...
    Item #4 for SAE
    McMaster-Carr
    Or here for metric...
    McMaster-Carr
    If you add a small serrated or split washer, they won't back off as easy in the future....
  7. DneprDave
    Maybe Radio Shack.
    Dave
  8. MaverickGun
    Aug 24, 2011
    34
    Thanks all for the good suggestions. I'll check around and see what I can find. It's nice to know that CravenSpeed will take care of me in the event I strike out locally :Thumbsup:
  9. john171
    john171 Club Coordinator
    Jun 13, 2010
    22
    PA
    Regardless of your final solution I'd follow Metalman's suggestion of adding a lock washer, or Loctite, even to the surving nut. :wink:
  10. Firebro17
    If all you are using on that sending unit is the one post, as I bet you might be, simply use the other nut and a lock washer as was suggested earlier. I can't tell if you have a remote sending unit there for that application, but if that's a Marshall set-up, the one post serves no function. Try it and see what happens. Otherwise just take the remaining nut to the hardware store and find a suitable replacement.....
  11. Tron Chief
    Tron Chief "Need More Coffee"
    60
    Maintenance Supervisor Del Monte, retired 30 year
    Lemoore California
    Awesome ideas from one and all.
  12. Kellen@Craven
    Kellen@Craven New Member
    36
    Talking about Minis and stuff
    Portland, OR
    Its Metric
    Thread is M4 x .7.
    Firebro is right, you only need a wire to be hooked up to the side marked G, so you should be able to just move the one you have over.
    If you need any help, I am always available.
  13. Firebro17
    ^^ Thanks Kellen. I can't take full credit, as a little bird that craves Sierra Nevada brew shared that with me when I installed my gauges...
