1st Gen R53 Cooper S Gear oil
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by MCS02, Apr 12, 2015.
  1. MCS02
    I'm doing a clutch on a friends car. What is the best oil for the trans. that is easy to get? I don't have time to order it in.
    Also I need to helicoil the oil pan. Someone put the mojo on the plug and its half striped. What size helicoil do I need?
  2. DneprDave
  3. cristo
    cristo Well-Known Member
    Jan 4, 2015
    5,651
    912
    physician
    York, Pa
    What kind of car does your friend have (make, model, year)?
    If an R53, with or without LSD?
  4. MCS02
    Opps! 2004 R53 no LDS
  5. cristo
    Jan 4, 2015
    5,651
    912
    physician
    York, Pa
    #5 cristo, Apr 12, 2015
    Official recommendations for 6-speed Getrag up to 7/2004 build date with or without
    LSD is MTF-94, which is very similar to Redline MTL.
    6-speed Getrag without LSD from 7/2004 on takes BMW MTF-LT-3, which is very similar to
    Redline D6 ATF (yes, ATF spec'd for a manual box). MTF-94 or Redline MTL can be used,
    but as it's a little thicker, it may cost 1/2 a mpg or so and maybe a little stiffer shifting in
    very cold weather.
    Any R53 6-speed Getrag with factory LSD takes MTF-94 (or Redline MTL).
    There's probably a sticker on the trans that says either MTF-94 or LT-3 (unless it fell off).
  6. MCS02
    Thanks so far I can't find MTF-94 or redline in area. All I have found so far is Valvoline MTF, but its spec sheet does not give a weight or say it will work in place of MTF-94
  7. cristo
    Jan 4, 2015
    5,651
    912
    physician
    York, Pa
    Not sure which Valvoline gear oil you're looking at, but the viscosity of the ones
    I could find on their site are way higher than that of MTF-94 or LT-3.
  8. Dave.0
    I will never use Redline MTF that stuff is junk.
    Factory fuild - pick it up at the local dealership
    AMSoil sever gear
    I have also used Enos and Motul
  9. Newbie6
    Newbie6 Member
    Apr 7, 2015
    I just ordered 2 quarts of redline to change out the trans oil and engine oil I'm using 5w-30 Liqui Molly, I have used it in my Audi and it is amazing oil
