1st Gen R53 Cooper S Gen 1 cylinder head tolerances?
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by dingels75, Aug 10, 2017.
  1. dingels75
    dingels75 New Member
    Telecom Engineer
    Purcellville, VA
    I have a warped cylinder head and have not been able to find the tolerances allowed for machining. My Gen 1, R53 warped head is .008 out. What is the maximum cut allowance with an oversized gasket? I've done goggle searches and this and other forums and haven't been able to find the info, maybe I'm just not using the correct search words thus the post. All advice is appreciated. Thanks!
    I am on the road or I would see if it is in the Bentley manual, maybe someone els here will be able to check. If not I will look Saturday when I get home. If you do a lot of your own work you should pick one up.
  3. dingels75
    Telecom Engineer
    Purcellville, VA
    Yes I do all of my own work and I should pick up a Bentley Manual.........it's rare that I can't find exactly what I'm looking for in a Google search, an existing forum discussion or in a youtube DIY. Thanks for your reply!!!
    I just checked my Bentley: "Maximum warpage allowed = 0.1 mm (0.004 in)". However, this appears to be the spec for max warpage on a usable head. There's nothing that I can find in there about a max cut allowance...you'll need a different source.
    FWIW, the thicker gasket avail from MINI is 0.037" while their standard gasket is 0.026".
  5. ColinGreene
    ColinGreene Well-Known Member
    438
    293
    Orange county Ca
    Jan at RMW would know or could find it because he builds motors on the regular
  6. Minidave
    4,592
    I've heard sometimes they can straighten them too, I'm from the old school where taking10 thou off to level a cylinder head is nothing....and the thicker gasket should bring it back to stock.
  7. JrTr
    JrTr New Member
    Jun 14, 2016
    There is a shop here that can straighten them. So, I guess you can have it done.
