2nd Gen R56 Cooper S Gen 2 Technical Service Bulletins (TSB) Database
Discussion in '2nd Generation: 2007+ R55 through R61' started by TheCheatOSX, Mar 23, 2011.
  1. TheCheatOSX
    TheCheatOSX New Member
    Jan 24, 2011
    27
    #1 TheCheatOSX, Mar 23, 2011
    MINI Gen 2 Technical Service Bulletins-Google Doc
    I've finished the database of all the TSBs I've discovered for the Gen 2 cars. The Google Doc has the SIM number, SIM Subject, and MediaFire link for the PDF download.
    MediaFire Folder with all TSB PDFs: Contains all the TSB PDFs discovered so far. You should be able to download the whole folder if desired. EDIT: I didn't realize you had to be a "pro" member of MediaFire to download the entire folder. Not the best solution, but for now I've made a zip file with all the current TSBs here: MINI TSB Archive.zip (11 Mb) EDIT 3/25/11: Updated zip file to contain an Excel spreadsheet and PDF of the database for offline usage. Excel file and PDF are also in the MediaFire folder.
    Please comment on any errors you've found or additional SIM numbers that are not in the list so they can be added.
  2. Metalman
    Nice job....
    Super info you dug up.
    I'll bet the 1st Gen folks are waiting their turn....
    Thanks again Chris
  3. TheCheatOSX
    Jan 24, 2011
    27
    The Zip file has went missing. Here is the new URL: MINI TSB Archive.zip
    I can't edit the OP for some reason.
