GNAT :: 2006 MINI Cooper S
Discussion in 'Member Garages' started by Nathan, Jun 3, 2011.
    GNAT :: 2006 MINI Cooper S (2009-07-09 23:08:39)
    Updated Garage to add the new ATI Crank Pulley, thanks Way (Way Motor Works) and Aaron (OutMotoring)
  3. Justa Jim
    I thought the two side stripes were over the left front fender. Did you move them?
    No, just have yet to post a picture of them yet, and it might be a while since that arch was coming off. I pulled it all the way off and ordered a new set of clips for both sides just now.
  5. Metalman
    Jim...... Virtual stripes for now.....:D
  6. Justa Jim
    Those are good. They can be anything the person looking at them thinks they are. :Thumbsup:
    Maybe we should go with a virtual M/A shirt next year.
  7. AliceCooper
    AliceCooper Club Coordinator
    Mar 13, 2010
    643
    123
    CT Technologist
    South Florida
    Umm....let us know when you get some mods on gnat. :)
  8. SilverCarbonFiber
    SilverCarbonFiber New Member
    Jan 16, 2012
    30
    I own a precision CNC mill and lathe/screwmachine
    South San Joaquin, just below the Sierra foothills
    Hey Nathan, I'm thinking of replacing my bushes with a PSRS from ALTA. Does yours make a noticeable difference? Do you use a lot of camber adjustment? Will they wear? or should I use some camber enhanced bushings?
  9. Nathan
    The PSRS are gone, replaced with poly bushings. Much quieter and still has a great feel.
  10. SilverCarbonFiber
    Jan 16, 2012
    30
    Thanks Nathan, this seems to be the common answer.
    From what I see the hot setup is to remove the PSRS if you have them. Me thinks the real hot setup is to never install them in the first place. :wink:
  12. Professor
    Professor New Member
    69
    BMW / MINI tech
    Kentucky
    20k on my psrs with no issue, no noise. Guess I got lucky?
  13. peep
    peep New Member
    Jan 29, 2013
    281
    82
    Central New Jersey
    beautiful looking MINI - I like the color but what is the roof graphic? i didnt see a pic of that...
  14. Jason Montague
    :cornut: Looks more like a Humming Bird than a Gnat but Gnat's probably an inside play on names.:Thumbsup:
  15. Nathan
    Thanks. The roof graphic is the same as the graphic on the left rear as seen here.
    I'll get a better picture sometime soon.
    Gnat hits the random garage!!! :Thumbsup:
  17. MyklMacD
    MyklMacD New Member
    Aug 26, 2013
    120
    Recovery Specialist @ WRC Telecare WRC
    Salem, OR
    Random Garage Sighting! :arf:
  18. Nathan
    Heh. Now you've seen it more than I have.
  20. MCS02
    6,317
    What a great MINI. I hope It wont be long before you'll be behind the wheel Nathan!
