Interior 1st Gen GPS location
Discussion in 'Tuning and Performance' started by wodturner, Feb 11, 2013.
  1. wodturner
    wodturner New Member
    Jan 13, 2013
    20
    Philadelphia, Pa.
    I have a Garman and would like to put it in the Mini for a semi permanent home. I have used the suction cut to the speedo for quick use. I have a 'goose neck' and it secures under a screw.
    Thoughts?
    THanks
    Bob
  2. Pretje
    Pretje New Member
    Jan 29, 2013
    20
    21
    Colorado
    Hey Bob, lots of options, but I just last week got a CravenSpeed "pro series" mount, and really like it. I think the price ($84) is beyond ridiculous for what is at the end of the day a tiny little piece of machined, painted aluminum, a 12v socket (that lets you completely conceal the wiring), and a few pieces of hardware (screws and spacers). But that being said, it's elegantly done and ideal IMHO. (It screws to the back of the tach, without hole-drilling—uses the factory holes.)
    Photos of the installation:
    Over-priced or not, I'd make the same decision again.
    Wes
  3. Justa Jim
    ^^^ I have the same set up, but I also have my iPhone on the other side. Love it, because everything is in line of sight and I never have to look down. Works great. :Thumbsup:
  4. Minidave
    I built my own, very similar to the one shown, only I arced mine to the left, so it's out of the view out the front. Works perfectly....and it's easy to reach to enter data or whatever.
    I'm pretty sure there are some pics of mine on this site already if you do a search.....
    found em...
  5. DneprDave
    I mounted mine to the lower left corner of the windshield, with the supplied suction cup mount, it looks much like Minidave's installation, from the front view.
    Dave
  6. ScottinBend
    I have the Craven mount also. Check my gallery for pic's.
  7. Pretje
    Pretje New Member
    Jan 29, 2013
    20
    21
    Colorado
    Nice job... After seeing what I got for my $84, I might have done the same, but my metalworking skills leave a lot to be desired. So as much as I grumble about the price? As I said, I'd do it again.
    But as I said, nice job!
  8. Tata Steva
    May 30, 2010
    407
    229
    DOP/stock Photography
    TO
    $5 item on eBay... A strip of double sided tape, 5min with heat gun (to "curve" the bottom) and that is it...
    Vote PEPPERNSALT for this month's MINI OF THE MONTH... Thanks.
  9. Mr. Jim
    That's the same one I have! Works great.
  10. Minidave
    I have to admit I copied the Craven Speed idea somewhat, but then modified it as they only had one leg supporting the Garmin, and I thought it needed two to keep it from vibrating and bouncing.
    I used to use the suction cup, but in hot weather I'd usually find my Garmin laying down on the floor or hanging by the cord, and I got tired of dealing with it. But I wanted something that I could remove again if I sold the car that wouldn't leave any marks, that's why I don't like the Kuda mount or the double sided tape solutions.
    I like the Craven Speed mounts a lot - spendy, but they work. I just decided I could make my own, so I did. Mine's just cut out of some scrap 1/4" aluminum strap I had, and then I welded the extra leg onto it. It's been on there for several years now and still works a treat. One of the things I like about the Craven Speed mounts is their adjustability, that way you can position it so you can easily see all of the unit, none of it's hidden behind the wheel, and of course you can take it off if you sell the car
  11. JECO
    JECO Active Member
    Apr 22, 2012
    228
    98
    Newsletter producer, retired DOT chief
    Crozet, VA
    My only criticism of the Craven Speed GPS mount is its tendency to vibrate. As I said in another posting on MA, if I ignore trying to be a perfectionist, I can live with the vibes.
  12. Justa Jim
    Mine vibrates a little if the road is really bad, but is very stable 90% of the time. I also rested one corner of the GPS on the rev counter, which helps stabilize it.
  13. Minidave
    That's exactly why I added the extra leg, and yet mine still shakes at idle sometimes (I have an automatic) but going down the road it's perfect.
  14. 2003 mini
    2003 mini New Member
    Jan 22, 2013
    12
    Is it easy to get the tach off to mount something on the back?
  15. Justa Jim
    In a word.......YES. :D
  16. Minidave
    Couple of screws at the base, IIRC.....depending on the year, but yes, it's a doddle....
  17. iwashmycar
    iwashmycar Active Member
    Jun 1, 2009
    881
    87
    architecture
    I had done the same. Just barely above the dash. Ran the cord by the A-pillar around the dash and under it to the plug. Worked excellently.
