Entertainment Electronics 1st Gen GPS Mount ideas...
Discussion in 'Tuning and Performance' started by Sin MINI, Jan 31, 2012.
  1. Sin MINI
    Sin MINI New Member
    Jan 1, 2010
    15
    Las Vegas, NV
    I had a Craven Speed flexpod in my R53 that bolted into the back of my Tach. I loved where it sat, until the attachment bolts stripped out the plastic in the tach and it fell out.
    Looking for an non-Tach mounted solution (also possibly an idea on how to fix my Tach...can I tap bigger holes in the plastic mounts?). Ideas?
    Note I have a Kuda dashboard mount for my iPhone. I've considered cutting a piece of thick aluminum about 6 inches long and drilling mounting hole locations at each end, attach it to the Kuda dash mount, and attach both the GPA and the iPhone to a single mount. Thoughts?
    I suction cup mount my Garmin to the speedo. Not very elegant, but it works for me.
  3. agranger
    1,486
    Hmmm... I've tried that a few times, but it never sticks for more than 5 minutes.
  4. agranger
    1,486
    A few years ago, I built a "CB" mic holder (actually for a VHF/FRS radio I've got installed in dash). It sits down near the radio, using the front facing radio mount screws (behind the oval down-tube). Maybe one of these pics will inspire a solution (just be careful to set the bracket low enough that you can still get a CD in and out of the radio).
  5. ScottinBend
    First.....try using a bit of silicone on the screw to the tach. It will set up and hold good and you can still get it out w/o any problems. In fact I would guess that it would hold up just fine with the GPS on it.
    Have you called CravenSpeed about this? They may have a better fix than that.
  6. agranger
    1,486
    Perhaps also you could fill the hole w/ JB Weld, re-drill and use tapping screws (or tap it by hand).
    You need better snot.... :biggrin5:
  8. 05r50
    05r50 Well-Known Member
    Dec 4, 2010
    1,269
    696
    Haha.
    It works for you because you aren't looking at the Speedo..........:biggrin5:
    No I watch the tach & look out the windows... :D
  10. Kellen@Craven
    Kellen@Craven New Member
    36
    Talking about Minis and stuff
    Portland, OR
    I bet I can help with this. We probably have some longer or even more coarse screws you can use, and we don't charge anything for stuff like that. Your CravenSpeed parts should work for as long as you drive your MINI, which is the same as saying forever right? Just PM me and we'll figure out what we can do.
  11. BRG_Paul
    BRG_Paul Active Member
    Nov 20, 2011
    758
    184
    Turbomachinery Engineer
    York, PA
    Agree...who needs a speedo?? ;)
  12. scf
    scf New Member
    Nov 21, 2011
    13
    Wouldn't be caught dead in one...
