Greene Performance Caster/Camber Plates
Discussion in 'Suspension' started by ColinGreene, Jun 27, 2015.
  1. ColinGreene
    ColinGreene Well-Known Member
    438
    293
    Orange county Ca
    Just wanted to announce I have pricing and drawings done on R53 caster camber plates, I should have a R56 top mount also soon enough.
    I was looking to do a group buy for these parts
    Retail pricing will be 425, Group buy price for the first 10 will be 375.
    Made in the USA out of CNC cut 6 thousand series aluminum then anodized.
    I decided to use a off the shelf bearing to make it easy to source and change should the bearing wear out or become damaged.
    If anyone is wondering why would you want to be able to change the caster?
    Adding caster will make the steering feel more steady on center, and it also decreases the need for extreme camber angle for front end grip. with additional caster as you turn the wheel off center it adds camber meaning the front end will not need more than two degrees of camber anymore.
    Here is some renderings of what we have been working on.
    The goal is to collect the money and get cutting within the next month.
  2. cct1
    Wow nice job!! To be able to take some negative camber out and have the same handling is huge--braking and acceleration are improved, handling remains the same, this is a bigtime upgrade over what we have for stand alone camber plates now.
  3. Dave.0
    Nice work Colin. :Thumbsup:
  4. Firebro17
    Please put me on the group list Colin. It's time to take the plunge and these seem more than logical.
  5. Apex
    Apex New Member
    Jan 19, 2014
    96
    NJ
    Colin, will these work with your coil overs, or are they only for shocks/springs?
  6. BlimeyCabrio
    Yeah, that's a good question. I know the Vorschlags require different top plate adapters for coils, OE struts and inverted monotubes like Bilstein
  7. ColinGreene
    438
    293
    Orange county Ca
    The goal is to have them work with stock as well as the coilovers.
    I can guarantee they will work with my coilovers/bc shocks though.
    if that goes well we will go on to doing monoball rear top mounts to eliminate that source of binding.
  8. Sleek Motoring
    Sleek Motoring Local Shop Owner
    Dec 7, 2014
    249
    143
    Mini repair shop owner
    Colorado Springs, Colorado
    May as well put me in for a set of these!
  9. WolfGTI
    WolfGTI Active Member
    May 21, 2009
    387
    217
    NJ
    Just saw this - you know I am in.
  10. ColinGreene
    438
    293
    Orange county Ca
  11. WolfGTI
    May 21, 2009
    387
    217
    NJ
    Order #1124 b i t c h !
  12. Firebro17
    BAM! Order #1126
  13. Dave.0
    Do not need them now but in the future I may pick up a set. I ah e other things I have going on now.
  14. Metalman
    I see you are working on your Scottish language skills...:Thumbsup:
  15. Savvy
    FTFY
  16. cct1
    Between you, Colin, and the dude on LXM who makes them up as he goes along, I've learned more acronyms in the past month than I care to admit.
  17. ColinGreene
    438
    293
    Orange county Ca
    So far have 3/10 needed.
  18. Firebro17
    Hopefull that Colin will get the orders necessary for him to move forward with this generous offer. C'mon folks, there's got to be more than just the three of us out there.
  19. Agbullet25
    Agbullet25 Member
    Apr 2, 2013
    40
    23
    Central Texas
    Is there any modification needed to the strut tower opening to gain full adjustment like is needed with the Vorschlags?
  20. ColinGreene
    438
    293
    Orange county Ca
    no unless you are seeking extreme alignment specs.
    Remember with adding caster you actually need less camber, so 2.0 degrees up front is very very attainable via the stock openings.
