1st Gen R53 Cooper S Guess what this was...
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Nathan, Apr 8, 2010.
    Can you guess what this was...
    No cheating Way or Chad...you already know...
  2. Rally
    Rally New Member
    50
    Ohio
    Definitely a muffler bearing
  3. Motoring Magic
    Motoring Magic New Member
    397
    266
    Thousand Oaks, Vta cty, socal
    ouch
    thats an ugly throw up bearing if I ever saw one
  4. imspencerwithanr53
    imspencerwithanr53 New Member
    May 27, 2009
    117
    Barista
    Portland, OR
    looks like a boner kill.
  5. Jason Montague
    :Thumbsup: Clutch throwout bearing,I think.:cornut: Jason
  6. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    This is what a T/O is suppose to look like.
  7. mini_racer
    mini_racer Well-Known Member
    Engr Manager
    Definitely............I bet it was mucho noisy.
  8. nabeshin
    nabeshin New Member
    Jun 8, 2009
    409
    Lincoln, NE
    Was that outta your car, Nate? Surely it made some kind of warning sound miles before this kind of failure. :crazy:
  9. Motoring Magic
    397
    266
    So I'm guessing that thing siezed to the collar first? Anyone seen this before, while we are on wierd R53 Clutch issues:
    NO noise, normal pedal feel, just would not disengage. The three sections are nearly identical in width, and car is completely stock, not modded or driven hard, 70k on it when this thing broke.
  10. Nathan
    It started as an intermittent whistle that many thought was in the exhaust. The pedal felt a little off, almost like there was a rock that was getting crunched. My first thought was the clutch slave cylinder was going south again. I drove it for another two days of mostly highway driving and there was still the intermittent whistle. That turned into a squeal at idle when in neutral. The death knell was when the pedal went to floor and would not come back. I was able to nurse the car home after getting it in first with the engine off then starting it in gear. Good thing it was at like 3am and only a mile or so from home. It went to the shop the very next day on a flatbed.
    The clutch slave cylinder had gone away. After that was replaced the noise was still there so it was torn down to diagnose. That is when the shrapnel you see was found. I hope to get the car back today.
  11. ScottinBend
    Has there been any work/word on a beefier replacement?
  12. phydeaux
    phydeaux New Member
    Maple Valley, WA
    Now I'm a little scared. 86+K miles on my '05... should I have already started salting away a bit here and there to be able to replace my clutch someday soon?
  13. Wikedmini
    Wikedmini MINI of the Month - December 2009
    Aug 17, 2009
    304
    13
    ouch
    DUDE.., Im at 138k and mines an 06!
  14. Nathan
    Just to clarify things. The clutch was fine. Has a few area of odd wear but would have probably lasted another 45K miles. The bearing went, not the clutch, pressure plate or flywheel.
    Keep in mind that I push things a little more than most and that probably accelerated the decline.
  15. Sideways
    Sideways New Member
    May 12, 2009
    539
    37
    Above the Border^^^
    So are you going back to OEM or are you going to upgrade?
  16. Robin Casady
    Robin Casady New Member
    134
    I didn't know they'd gone digital. :smilewinkgrin:
  17. BThayer23
    What kind of upgrades are there to the throwout bearing? :confused5:
  18. beaner
    beaner New Member
    44
    The OS Giken thowout bearings are much more stout. They only work with their own clutch and flywheel, however. They are available through MA sponsor, Werkin' MINI.
  19. Jason Montague
    :frown5: Looking at it, the failures are very symmetrical. Every 120degrees/crack! I'm not an engineer but there appears to be a lot of evidence of heat damage. Poor alloy/temper of metal? Higher heat than normal, reason unknown? 'Popping the clutch' and 'speed shifting' too much(no Jason,no real Mini driver would ever do that:lol:). I don't know, but one of our more knowledgable will see this and give us an explanation. :Thumbsup: Jason
  20. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    The only upgrade to a t/o might be a hydraulic conversion? There is no "beefier" t/o bearing out there for a mini yet? Bearings are bearings.....But if someone claims to have one I would like to use it.
