Had an "interesting" thing happen to my MCS
Discussion in 'Mid-Ohio Motoring' started by wmwny, Jul 27, 2011.
  1. wmwny
    4,040
    2,242
    ...and wound up at MAG for the last 2 days. I guess you should all take note of this. Saturday, I went to the grocery, parked the car, made my purchases and returned to leave. I started the car and all of a sudden the gas needle went from full to empty and my computer readout read that I had no gas. I limped home, fearful all the way that the computer would shut the engine down, and called MAG. They gave me an appt. for Tuesday, and the car sat in my garage until then, as I was afraid to even start it up. Yesterday, I went out and started it up and the needle returned to "normal". All seemed well, and I took the MCS to MAG, anyway. Amber came out and as I started the engine again, again, the needle went back to empty. So, the MCS remained at MAG until they figured out the problem.
    The problem was that there are 2 fuel sensors in the tank and when one goes, the other is sure to follow. The fact that one of mine was still functioning was just a band-aid, as the onboard computer could have shut me down at any time...even though I had a full tank of gas. The sensors are only sold in pairs, so MAG had to order a new set for me...to the tune of $633! :(
    They gave me a new Bimmer 325i to take home...NEVER will I ever consider getting a Bimmer. What a POS...terrible mileage, awful ride, and it was noisy as all get out. And, for only a 140 mile roundtrip, I had to put $31 of premium into that gas-sucking pig.
    Just thought I'd clue you all in for what you are facing if your gas needle drops to "empty", unexpectedly.
  2. goaljnky
    3,105
    394
    Had that happen to me while still under warranty years ago. Happened again couple of weeks ago, but been fine thus far. $633 seems a bit much though.
    Those are made of solid gold & crafted by elves in the Bavarian woods. :rolleyes:
    Jeff, thanks for the heads up. Hope it does not happen to my MINI. Was it the S or the Cooper?
  4. wmwny
    4,040
    2,242
    It was the S. I'm just glad it has been fixed...has a 2-year warranty. I'm headed to Putnam Park the second week of Aug., so I am relieved...now. Imagine if it had happened over there....:(
    Was that price for the just the parts or was labor included?
    MAG has outrageous parts pricing. When I pointed out MSRP on the overpriced parts they kept tossing at my car in order to fix the crank pulley they did a lot of backpedaling and adjusted them. One needs to research the parts price before OKing any work with MAG.
    Fuel filter with fuel level sensor 16-14-6-765-124 MSRP $218.00
    Right Side Fuel Level Sensor 16-14-6-765-134 MSRP $99.72
  6. Kikimowse
    Kikimowse Active Member
    25
    California
    Now this is an interesting thread. Let's compare dates and time...... My 2007 S Cabrio did the same thing on Monday. Freaked me out at first, since like all good trained gerbils we believe what the gauge tells us. After a moment or two I realized that the read out simply could not be true as I had filled up the prior Wednesday and had only driven a little over 25 miles since. Drove the car home and shut it off. Turned the ignition back on again and the needle returned to normal and the red light went out. Two days later it has not malfunctioned since. Could it be sun spots or aliens? The X-Files? :ihih:
  7. goaljnky
    3,105
    394
    I actually know for a fact that both times I experienced this, the outside temp was in the "damn hot" range.
    I can't see how a MINI with fuel in it is going to stop running. Unless the fuel pump is somehow fooled into believing there is no fuel to pump. Jeff did your MINI stop running or was it just the dead gauge?
    Seems to me a work around would be to zero the trip odo at fill up & watch the miles. That is unless the MINI dies from a lack of the fuel gauge senders.
  9. goaljnky
    3,105
    394
    Exactly,. Last time this happened to me was right after I filled up for the trip. I then proceeded to drive 130 miles or so with no issues.
  10. wmwny
    4,040
    2,242
    Labor was included. MAG DID credit me with the shipping price for the parts they ordered and BMW charged me [$14], but the big savings was that I was able to use one of those coupons they send out every now and then. They took $100 off the bill so I actually ended up paying a bit over $500, instead.
    As I was about to leave, the mechanic came up and asked me what kind of gas I had put in the car and I replied, "Premium, 93 octane". He said it's the first time that Premium has ever burned his arm as he was draining a gas tank. His arm looked like raw meat.
  11. wmwny
    4,040
    2,242
    My experience last Saturday was in the "damned hot" range, too, but on Tuesday, the car didn't do it again until after I had made the 70 mile trip to the dealer. I'm just glad it happened again with a rep present, so they wouldn't think I was "funnin" them.
  12. wmwny
    4,040
    2,242
    I thought that, too, but MAG told me that the computer would eventually read the "no fuel" needle as the tank actually not having fuel and the engine would shut off because of the "no fuel" readings from the sensors. I also noticed that the mpg readout was at "0" when all this was happening. When I restarted the car for the trio to MAG on tuesday, all the gauges were back to normal. It was only after the car had made the trip to Dublin that the whole mess started all over again, and luckily for me, Amber was there to see it.
    I can only imagine the concern and consternation I'd have gone through if I was on my way to Putnam Park and the engine shut down, because I usually drive back roads [US 36...which is nearly deserted] and only get onto I-70 for the last 70 miles or so.
  13. wmwny
    4,040
    2,242
    I understand that, but, since I am not mechanical [don't have the knowledge to do a price scan for parts I know nothing about, anyway], and since I was perplexed at what was happening, and since MAG IS the dealer I go to for service, it just seemed like a wise decision on my part to go there. They have always repaired my MINIs [the MCS and the Cooper] and I have always been pleased with their service.
  14. BThayer23
    Why did the gas burn the mechanic's arm? Was it a chemical burn or just a really hot day?
  15. goaljnky
    3,105
    394
    Sorry, but that is wrong. Once again, speaking from experience (sadly), the computer will not shut the car down. I've ran out of gas twice and both times the engine shutdown because it was out of gas, not because the computer told it so.
  16. Justa Jim
    Ran out of gas TWICE?????? Was the second time to be sure the first time was not a fluke? :lol::lol:
  17. goaljnky
    3,105
    394
    Meh.. I usually can ride my cars till I see zeros on the range. A few times I've even driven where the range just had three dashes. This brings us to the second occurrence. I was about a mile and a quarter from the house with 3 miles on the range. Then all of a sudden it went to zero and the engine stopped running. But at least now I can end any argument on exactly how much gas the tank will hold. :cornut:
  18. Nathan
    How much is that?
  19. goaljnky
    3,105
    394
    Largest Fuel Fill I have recorded is 14.772 gallons. Add another half gallon to a gallon from my emergency can that got me to the gas station.
  20. Justa Jim
    Rather then fill up BEFORE the gauge reaches empty, you prefer to carry an emergency can of gas? I'm not saying there is anything wrong with this approach, but would you share the thought process behind it please? :eek6:
