Hans Question
Discussion in 'Track Days & HPDE's' started by roach13, Jun 19, 2009.
  1. roach13
    roach13 New Member
    May 14, 2009
    73
    Doing my first instructing this weekend, so the question is does anybody know if leaving the Hans attached to the helmet could do any harm.
    The Hans is a pain to attach and unattach so it would be lots easier to just leave it on.
  2. Ryephile
    Ryephile New Member
    Apr 9, 2009
    299
    122
    Yes!
    Metro Detroit
    I always see the F1 guys leave it attached as they remove their helmets, so I can't see why it'd be a problem other than you have to remember it's attached so you don't rip your head off!
  3. minispeedrcr
    minispeedrcr New Member
    May 20, 2009
    54
    I leave mine on till the end of the day.
  4. BThayer23
    I've seen local instructors just leave the HANS attached to their helmets. It's kind of awkward to take on and off, but I can't imagine how it would cause any harm.
  5. ScottinBend
    Are you instructing in a class that has 5 or 6 point harness's?
  6. roach13
    roach13 New Member
    May 14, 2009
    73
    Probably not, don't know what car my student will have most likely a Porsche of some ilk.
    Anyway once I looked at the helmet for a bit it's easy to remove and replace the HANS, couple of weekends ago I replaced the old quick release with the sliding tethers. When I had the quick release the attachment loops stayed on the helmet so it was easy. There is a "washer" on the helmet that must have a spring under so all you do is push it down and the tethers snap on.
    Put a cool shirt system in this will be the first time to use that, it'll be nice, going to be in the 90's this weekend.
    Instructors can run in any group so it'll be drive till you drop this weekend.
  7. ScottinBend
    I guess I don't understand the question then......I thought you couldn't wear a HANS unless you were using 5/6 point belts?
  8. BThayer23
    Correct me if I'm wrong, but isn't the HANS just held in place by the shoulder straps of the harness? And if you're only wearing a 3-pt belt, it wouldn't work as intended, but it'd still restrict somewhat the excessive head motion?
  9. roach13
    roach13 New Member
    May 14, 2009
    73
    Held in place by mounts on your helmet.
    Anyway day can short AST shock sheared on the front corner. This is the second one to do this. The could be a major problem if it happened at speed in the wrong place on track.
  10. BThayer23
    Gotcha. The wikipedia article is actually pretty good on this one - good diagram, too.
    [ame=http://en.wikipedia.org/wiki/HANS_device]HANS device - Wikipedia, the free encyclopedia[/ame]
    Holy cow. Which part of the shock sheared? Upper strut mount bolts?
  11. roach13
    roach13 New Member
    May 14, 2009
    73
  12. ScottinBend
    I agree that the HANS is attached to the helmet, that is how it restricts the movement. But w/o a 6 point you are allowing the HANS to move around and not perform as designed.
  13. BThayer23
    pics?
