1st Gen R53 Cooper S Hard/sloppy shifting
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by west7, Feb 17, 2012.
  1. west7
    west7 Member
    Sep 17, 2011
    136
    17
    Indianapolis, IN
    I have a 2006 cooper s (manual) that I purchase in Jan of 2011. I ended up noticing a bad hydraulic motor mount just after the 30 day warranty was gone and ended up replacing it with a tsw. About the time I notice the bad mount, I noticed additional play in the shifter and noticed it became intermittently difficult to shift into rev, first, and second. What could be causing this and what can I do to fix it?
  2. goaljnky
    3,105
    394
    Check your slave cylinder for leaking.
  3. agranger
    1,486
    #3 agranger, Feb 17, 2012
    If the slave is leaking, that would make it hard to shift. Basically, the clutch system is losing pressure and it would be like trying to shift with your foot only half way down on the clutch.
    I check the slave (well... the whole clutch hydraulic system, but the slave tends to be the weak point) by stopping on a level surface (where the car won't roll on it's own if left in neutral and no brake was on). Start the car, put it into first gear and stay there, with the clutch to the floor, for a minute or two (no brakes). If the car starts creeping forward, it's probably leaking from the slave.
    A how-to for the slave replacement is here: http://www.motoringalliance.com/library/1st-generation-mini-cooper-how-to-3/how-to-replace-a-clutch-slave-cylinder-and-bleed-the-clutch-56/#axzz1mfn83CDC
    If you wanna get dirty and actually see it leak before you replace it, the slave is just under the front bumper. You have to remove the plastic under tray (4-5 bolts) to see it, though.
    You can see the accordian dust boot in this pic. To the right of the accordian is a smooth section of the rubber boot that seals the accordian to the slave. If you pull that back a bit and your slave is leaking, fluid will probably come out. If you just squeeze the accordian and your slave is leaking, you will probably hear/feel the fluid squish around in there.
    Sometimes it develops a leak at the junction of the slave and the input pipe (the black pipe coming down on the right side of the pic). If so, you may also need to replace that section of pipe (~1 hour to move all the stuff to let you do the work and a $20 part + time to replace the slave + time to bleed the clutch hydraulics). The new slave should cost you $60 and fluid about $20.
    I think our local Dallas dealers charge in the $300 range for a slave replacement, including parts, labor and fluids.
  4. agranger
    1,486
    OK... now that I got my slave cyl. knowledge dumped, it's possible that you have a broken lower motor mount or transmission mount. Either of these might, when at an extreme, cause difficult shifting too.
    On the '06 MCS, that hydraulic mount is always popping (I made it about 15k miles on each one that I installed, finally going for the TSW solid mount as you did). I'm also on slave #4, I think... Other than that, my car has been pretty reliable for the past 6 years and 76k miles.
    My first mount lasted about 30,000. The second one is going strong at 73,000. I'll go with another oem if this one goes all limp. I'm not a fan of things that add NVH.
  6. BThayer23
    There's some shift linkage on the transmission that can become worn with age. If you remove the airbox, it's right there. You can wiggle it around and see if that's what's causing the play. Some play is normal, but it shouldn't be sloppy.
  7. TSR53
    TSR53 New Member
    Jan 8, 2012
    I can guarantee it is the shifting linkage under the airbox. Remove the airbox and lubricate the linkage parts with white lithium for colder temps and wheel bearing grease in warmer temps. Your shifting will improve.
  8. west7
    west7 Member
    Sep 17, 2011
    136
    17
    Indianapolis, IN
    Thanks for all the responses! I tried the level surface trick last night after work and did not get any creep. I will get under the car and inspect the slave cylinder and pull the air box off and inspect the linkage this evening or tom. I'll make sure and post what i find.
    Just curious, how much play do you guys have in you shift linkage (at the shift knob)?
  9. BThayer23
    If memory serves, maybe 1/2"? (at 110,000 miles)
  10. TSR53
    TSR53 New Member
    Jan 8, 2012
    Agree with BThayer, about 1/2" back and forth total. This is due to the lubrication that dries out in the right side ball cup under the shifter boot. If you pull up the shift boot cover and add new white lithium grease in the shifter cups (center and side) this sideways slop will reduce a little.
    Again, to cure the stiff and reluctant shifting into reverse and other gears, lube that shifter mechanism under the airbox.
  11. west7
    west7 Member
    Sep 17, 2011
    136
    17
    Indianapolis, IN
    I ended up having family over this past weekend and wasn't able to check the linkage yet, but I was able to inspect the slave cylinder. I saw no evidence of fluid leakage. The black line connection looked dry. I slid the accordion boot off and it appeared pretty dry. I noticed that I could physically press the clutch arm, which presses against the slave cylinder, and move it backwards,compressing the accordion boot. Should I be able to do that or does the slave cylinder need bled?
  12. west7
    west7 Member
    Sep 17, 2011
    136
    17
    Indianapolis, IN
    Mine has about a half inch or so of play as well. Glad to hear that's reasonable.
  13. k-huevo
    k-huevo Club Coordinator
    159
    Pipe Creek, Texas
    Since the history of this car is unknown, I suggest more than one procedure. First change the transmission fluid. I recommend OEM MTF-94, but that can be a hassle for some to collect from the dealership, in its place Red Line MTL is a good substitute. Drain the old fluid into a clean container, and drag a magnet through it. The transmission has a magnet inside, but large bits can bypass without being attracted. If there is more than a few flakes on the magnet there may be an internal problem, a cracked shift fork wouldn't show till it broke completely however.
    Remove the heat shield from the center canal. Although it can be done without removing the exhaust, it is much easier to do without the exhaust in the way. Remove the dust cover from below the shift box. It is possible a previous owner installed an extension on the shifter end which may be rubbing on the side of the box, or has loosened; hence increased play and shift difficulty. In any case disconnect the cable ends. Look at the connect to the side of the shift shaft. Remove the shift shaft boot from above, unclip the collet over the shift ball, inspect the retaining collet for cracks or broken tabs, clean and re-grease the ball. Disconnect the cable ends from atop the transmission, push and pull the ends. If there is resistance, the Bowden cable(s) should be replaced. It is not so much a problem with your model year because there are dust boots on the housing ends and the design changed from the early models, but it is still possible for a cable to kink, bog from lack of lube, or wear restrictive grooves within the housing.
    If the condition progresses in spite of maintenance attempts, the clutch release bearing may have collapsed, or debris may be preventing the clutch pressure ring from disengaging completely, or the flywheel may be on the fritz.
  14. west7
    west7 Member
    Sep 17, 2011
    136
    17
    Indianapolis, IN
    Wow! Thanks for the thorough response K-huevo! It will probably be a week or two before I can perform the diagnosis you've recommended but that is definitely on my list of things to do! I did notice a noise from my clutch when I'm in neutral and the clutch is released. It's been there since I bought the car. The dealer said it wouldn't hurt anything and there was no need for replacement. More recently I've noticed a similar noise whether the clutch is engaged or not. It very well be a release bearing and or flywheel issue. :/
