1st Gen R53 Cooper S Hard starting when below 1/4 tank of fuel
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by jasonsmf, Mar 4, 2016.
  1. jasonsmf
    jasonsmf Active Member
    111
    27
    engineer
    Elyria, Ohio
    I've noticed that it's taking more cranking to start (06 R53, 196k miles) my car when I'm below 1/4 tank of fuel. Otherwise it runs beautifully, and when the tank if full it starts up just as quick as ever. Seems like fuel pressure is bleeding off and the system has to re-prime. Not other issues, and no CEL.
    My guess is that the fuel pump assembly is starting to show it's age. Has anyone else experienced this?
  2. Grizld700
    Grizld700 Well-Known Member
    Feb 2, 2016
    1,212
    47
    Eastern Iowa
    Ever change the filter?
    They are NOT lifetime like MINI claims.
    [ame="https://www.youtube.com/watch?v=rCppUQfNZQQ"]Replace Fuel Filter - Gen 1 MINI Cooper R50 R52 R53 - YouTube[/ame]
  4. jasonsmf
    111
    27
    engineer
    Elyria, Ohio
    Thanks for the info guys!
    I don't think I'd have any need for an uprated pump at my moderate power level, but thanks for the link.
    I did replace the fuel filter a few years ago, but that's not to say I couldn't have picked up a bunch of crud since then. Thanks.
  5. Dave.0
    Add more fuel???
  6. Grizld700
    Feb 2, 2016
    1,212
    47
    Eastern Iowa
    Sure, but its still less expensive than the OEM unit
  7. jasonsmf
    111
    27
    engineer
    Elyria, Ohio
    Ok, I was basing it off of a VDO replacement for $195.
  8. nkfry
    nkfry New Member
    Roseville, MI
    It's weird that it would've just started, but I've had to redo customer installed fuel filters due to them either omitting the o-rings, or the o-rings not seating properly causing a bleed off of pressure.
    Matter of fact I had to do this in my car when I first bought it due to the same predicament.
  9. jasonsmf
    111
    27
    engineer
    Elyria, Ohio
    nkfry, That's interesting and easy to check as I have a brand new filter/seals on the shelf. This current filter has been installed for 2 or 3 years; this hard start problem has been going on for maybe 6 months.
    Thanks,
  10. fishmonger
    fishmonger Well-Known Member
    May 13, 2015
    984
    769
    Madison, WI
    how long do you keep your pump running before you fully turn your key? You can hear the fuel pump pressurizing the system - when that sound stops, you should be able to start the car normally, or at least the fuel pressure should be up to spec and neither pump nor filter should impact the startup negatively.
    It does sound like a filthy filter (they have less surface to filter when the tank is low, reducing flow just because once your fuel drops, only a small part of the filter surface is used, plus the crud usually collects most near the bottom due to gravity, plus it is the part of the filter that is always in use.
  11. MCS02
    Its the battery! its always the battery.:D
  12. jasonsmf
    111
    27
    engineer
    Elyria, Ohio
    If it was a filthy filter, wouldn't I be also experiencing problems at high RPM/ high load situations? Other than startup, it sure doesn't feel like I'm starving for fuel.
  13. Dave.0
    ^^^ Exactly add more fuel or change your fuel filter.
    Fuel is cheap now. :ihih:
    I'd sure think so.
  15. fishmonger
    May 13, 2015
    984
    769
    Madison, WI
    well, how long do you pre-pressurize the fuel system before startup? If the filter is clogged the pump has a hard time geting pressure built up. Once there is pressure, it recirculates back to the tank anyway. For most driving situations, once there is enough pressure, there's plenty of fuel available. Cold starts also require a surprisingly large amount of fuel.
    And after you start the car and run it for a few minutes, will it start up fine after a brief stop? Fuel pressure will drop over a period of time, but it should not drop that quickly. If it starts up poorly even then, you have a very different problem
    If the car starts poorly only after standing overnight, you may have a leak somewhere in the system, tiny, but enough to drain all the fuel from the line back into the tank. Starting with a full keyturn under those conditions will have the engine struggle to get going.
    My filter caused problems only when I was driving up long mountain grades at a good clip, requiring a higher fuel flow over extended time (below 18mpg on the realtime gauge). Places like Vail Pass on I 80 would have the car cut out near the top of the grade, then bump start again as fuel pressure rebuilt during the hiccup, etc - idle it a minute at the side of the road and it was fine for a few miles again. No codes, just no fuel with a full tank or half a tank. Now that I think of it, the lower the fuel tank was on that trip, the more often the car would do that. However, startups and short bursts even at full throttle never were a problem with that dirty filter.
  16. fishmonger
    May 13, 2015
    984
    769
    Madison, WI
    forget what I said about the low fuel and the filter being used only for the lower half of it's filter element. That's not how it works, actually. I somehow remembered this large thing in the tank, but that's just an enclosure, the filter is much smaller inside that thing and he pump pushes fuel into the filter enclosure through the filter. So unless you are almost totally out of fuel the filter will be fully submerged.
    It's really difficult to make sense out of that 1/4 tank thing based on the setup inside the tank. the pump picks up fuel from the very bottom of the unit right on the bottom of the tank. Unless the pump intake is so clogged that it needs more fuel pressure by gravity to work well, there's just no way the fuel level would affect the performance of the pump.
    There's a small pump under the fuel filter that is used to level the two sides of the tank, but if it failed you'd just run out of fuel earlier. Nothing that matters at engine startup.
    Still would not be a bad idea to swap that fuel filter given the high miles you have on that car and the filter.
  17. jasonsmf
    111
    27
    engineer
    Elyria, Ohio
    Just a quick follow up:
    I went ahead and replaced the filter - paying very close attention to the o-rings. All of the o-rings were in place and appeared in good condition, but I put the new ones in for good measure. The filter itself didn't appear very dirty (as I kinda expected after only a couple years of service).
    No difference in my hard start issue, still struggles when under about 1/4 tank. If I do "prime" the system before starting, it does start right up. I can actually hear the fuel pump change it's tone as it builds pressure back up when priming, so I'm 99.9% certain this is a pressure leak down issue.
    Leaning back towards the fuel pump as the issue now.
  18. Dave.0
  19. ScottinBend
    Waterish gas at the bottom of the tank?
  20. jasonsmf
    111
    27
    engineer
    Elyria, Ohio
    I'm not sure how this would cause a leakdown of fuel pressure?
