Seems Poco's hatch latch does not want to work. I had opened and closed it a couple of times today while running errands, worked fine. Get home, unload him, now it won't latch. Have to deal with this when it warms up a bit. Mark
Fixed! Seems the latch somehow got out of sync. Played with the release button, door lock switch, and now it works. It was bugging me, cold or no cold. Mark
Yeah, I need to do that. It does get out of sync every now and then. I think I don't push and hold the release button on the hatch long enough, and it does not cycle completely. Mark
I had to replace my trunk latch last year. It had been buzzing upon opening for a while, then finally wouldn't close at all. It was bungee corded down for a few days before I got the part.
So, pull some plastic from the boot, un-bolt latch, disconnect power, reconnect power, bolt in new latch, put plastic back in boot? Mark
It was, pull some plastic from the boot, disconnect power(plug from latch), un-bolt latch, bolt in new latch, reconnect power(plug into latch), put plastic back in boot.
I found that if you twist the rubber bumps on the hatch itself you can raise or lower them. I was having issues with closing. After I twisted them "in" a few turns, problem was gone. As for opening... havn't had any issues.
That's what I figured, thanks Just make sure that you don't turn them in to much, or you will get rattle hatch. Mark
