1st Gen R53 Cooper S Head Gasket issues
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by chod, Mar 2, 2015.
  1. chod
    chod New Member
    Dec 31, 2014
    Contractor
    Glendale, AZ
    I have a 2002 R53 that I think has a blown head gasket. It has been a great car with very few issues. It now has 186,000 miles on it and according to our mechanic needs a new head gasket. She priced the repair at around $3600 which I don't want to spend on it. I don't need the car to drive daily, so I thought this would be a fun project. Does anyone have some advice before I dive in? Would a new engine be warranted?, a new head (with gaskets?), or just new gaskets and seals (with some valve cleaning)?
    6,278
    First post. Welcome to MA. When you pull the head off have a meachine shop check that it is still flat. This in the perfect time for MODs
  3. cristo
    cristo Well-Known Member
    Jan 4, 2015
    5,652
    912
    physician
    York, Pa
    $3600 to replace a blown head gasket sounds steep.
    For that, you should be able to put in a ported and polished
    head with a cam and have some change left over, providing
    the old head is good for the core charge.
  4. ZippyNH
    That's very high....
    Dealer?
    maybe it is assuming the head is warped and the valves are bad....
    But still....
    Many have said the gen1 mini head is not very difficult.....so should not be so $$ if it is JUST a head gasket IMO....
  5. Dave.0
    Welcome to M\A the FUN MINI site. :Thumbsup:
  6. cct1
    Run away from that place. Or ask for a packet of whatever they're smoking; it must be some pretty good stuff.
  7. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    If you're going to do it yourself, take the head to a good machine shop to 'check it and deck it'. the parts will be cheap, but you might want to get yourself the 'cam tool' to set the engine at MDC. The other 'special tool' needed is the engine bracket, but you can make one of those with some square stock and a drill. You'll see what I'm talking about. Go for it!
  8. Dave.0
  9. Nathan
  10. nkfry
    nkfry New Member
    Roseville, MI
    #10 nkfry, Mar 3, 2015
    What is the exact proof the car needs a head gasket? These cars rarely have HG issues. I would as for a compression check and leak down test to start with. I have seen a couple of cars that the head cracks around the first head bolt at the rear of the engine on the passenger side, which then progresses down the side of the head into the timing housing.
    Pic for reference:
  11. c0op3r
    c0op3r Active Member
    Oct 2, 2013
    196
    133
    Mech Eng and IT
    Orlando FL
    Cristo is basically correct
    I recently had an RMW head made (thanx Jan) and had it installed, with Injectors, new gasket kit (complete kit) and new spark plugs and the total was less than 4k$
