Header........
Discussion in 'Tuning and Performance' started by ScottinBend, Sep 24, 2018.
  1. ScottinBend
    So, RMW shorty or Milltek?
    And wrapped or not....
    Thanks
    RMW shorty not wrapped.
  3. Goldsmithy
    Jan 30, 2015
    1,748
    982
    TCB
    Main Street in the land of Oz
    I just got my RMW street header with a Milltec exhaust. It seemed to 'open' up my engine and resulted in much more balanced power. At least according to my 'butt' dyno.
  4. BlwnAway
    BlwnAway Well-Known Member
    Nov 24, 2011
    474
    290
    Honestly, with your mods either would work, if you think you may do more engine work in the future, get the RMW and you'll never have to worry about an upgrade, otherwise just do what your wallet says is best for you.
    As for wrap, I wouldn't.
    The only time I'd wrap something is if it was very exposed and easy to get on and off.
    Wrap collects oil, oil catches fire, so unless you have no leaks and never will have, or can easily get to the wrapped item to carefully watch it and re-wrap when needed, go with ceramic coating or nothing.
  5. ScottinBend
    Thanks all. Went with the tried and true RMW and non-res Milltek.
    Any tips on additional parts before I dive in and create a mess in the garage.
  6. Dave.0
    #6 Dave.0, Sep 25, 2018
  7. fishmonger
    fishmonger Well-Known Member
    May 13, 2015
    984
    769
    Madison, WI
    I bought those gaskets for my Milltek - don't fit, had to throw them out after trying to cut to proper size. I ended up using what came with the Milltek. The holes are too far apart to fit on the stock header at least, and that graphite cannot easily be cut to fit. Need a punch like tool for that. Maybe this fits on RMW stuff.
    • Informative Informative x 1
  8. ScottinBend
    Got this yesterday..........with gaskets.
    :Thumbsup::Thumbsup:
  9. MCS02
    Beets my OBX!:D
  10. Sully
    Sully Administrator
    Jul 21, 2015
    2,100
    916
    Software
    30350
    Agreed - Ceramic coating is the best way to go. I did this to my 88M5 Euro Headers and the temp difference was pretty significant. I plan to do that to the GP when I get to actually tuning it verses working on the site. :rolleyes:
  11. ScottinBend
    So, getting ready to tackle the installation. My first time doing this. Used to see guys using a spray on copper gasket to help with assembly, good or bad on the manifold gasket? Head bolts?
    Car has 70K miles, new O2 sensors?
    Any other tips for me?
    Thanks
  12. MCS02
    I didn’t use it, no leaks. My header has been on there a long long time.
  13. Dave.0
    I did not use any copper spray. Everything matches right up with the gasket perfectly.
    • Like Like x 3
  14. BlwnAway
    Nov 24, 2011
    474
    290
    As far as the Copper Spray it's one of those "shouldn't need it" items, but won't hurt if you do.
    Most of the brands of gaskets hold up really well and can be reused, then I'd spray it for extra sealing, but it's not necessarily on a new one.
    • Like Like x 2
  15. Whine not Walnuts
    Mar 14, 2017
    359
    253
    waitin for my check
    Fuquay Varina, NC
    Thinking that Jan went to ceramic coating on his headers.
    I looked into all that when I put my mine on and decided to just put it on right out of the box. If tracking the heat may be of issue but for street and the occasional mountain run could not justify the cost. From what I researched the best stuff is the white heat coating from somebody like Swan Tech.
  16. ScottinBend
    Thanks.
    I think the copper spray was more to hold the gasket in place than for additional sealing properties, but what do I know.....o_O
    Been watching some videos of the procedure and not sure I will have enough room under the car on the jack stands......no lift :mad: so I may end up going to my exhaust shop to have it done.
  17. Dave.0
    Yes, it is a pain in the ass on jack stands.
  18. Whine not Walnuts
    Mar 14, 2017
    359
    253
    waitin for my check
    Fuquay Varina, NC
    I did mine on jack stands but I used some solid 4" blocks to put the jack stands on so that the car sat even higher up. I had to remove the heat shields that travel up toward the power steering and coolant reservoirs. Would think my 4-2-1 is a little bigger than Jan's 4-1 as well.
    A few chosen curse words and then some prayers got the sucker up in there.
    • Informative Informative x 2
    • Like Like x 1
  19. MCS02
    I did mine on jack stands also. It was a major pain. It was like a puzzle. I think if I do it agin I would drop the sub fram a little
  20. Whine not Walnuts
    Mar 14, 2017
    359
    253
    waitin for my check
    Fuquay Varina, NC
    Yes dropping the subframe is a great idea as even a 1/4" makes all the difference in world.
