1st Gen R53 Cooper S Headliner repair tips or tricks?
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by rivercityRN, Aug 3, 2015.
  1. rivercityRN
    rivercityRN New Member
    Oct 15, 2013
    39
    20
    RN
    Chattanooga, TN
    My headliner is starting to sag along the passenger side. Summertime in Chattanooga is freaking hot and without A/C (another future project), sunroof open and both windows down is a must. However, billowing in the wind at high speed is causing the headliner to progressively get worse. Rather than take it somewhere for replacement, I thought I'd check to see if guys could recommend any products for a DIY fix?
  2. r34king
    r34king Member
    Aug 18, 2011
    71
    34
    Auto Tech NTB Capital BLVD
    Straight pins. Just remember there is an air bag behind it. Be careful.
  3. Norm03s
    Norm03s New Member
    534
    Working at being retired.
    Somewhere in Sykesville. Md.
    Help Dave
  4. ZippyNH
    Staples? Voodoo?
    Generations of folks have tried tricks to "save" a failing headliner....
    Don't think anything short of yanking it out, and regluing it has ever fixed one...
  5. rivercityRN
    Oct 15, 2013
    39
    20
    RN
    Chattanooga, TN
    r34king, I'm looking for an "aesthetically pleasing" solution:) Something along the lines of a spray adhesive?
  6. Zapski
    I'm with Zippy. Pull it out, and re-glue it. It's the only way to be sure. :)
  7. Minidave
    Not possible......
    The headliner material is bonded to a foam backing which is glued to the cardboard form, it's the foam that has failed - it's disintegrated into dust, there is nothing to attach the headliner material to.
    The only way to fix it is to remove the entire cardboard framework, scrape off the headliner and glue a new one on - the new one will come with the foam already bonded to it.
    Sorry, but there have been millions of these replaced on all different brands of cars. It's not that hard to do, I've done several, from a Rabbit to a big Ford sedan.....
  8. MCS02
    6,317
    The best way to fix it is to pull the headliner board out take the old headliner off, clean off any foam residue from the backing and glue a new peace back on, then reinstall it.
    The fabric comes with the foam attached and 3m makes a glue for the job.
  9. MCS02
    6,317
    Minidave you type faster than me!
  10. Minidave
    Great minds, right? :Thumbsup:
  11. ZippyNH
    #11 ZippyNH, Aug 3, 2015
    Yup...
    Or choose the other material of your choice...
    One tip...
    Not all years were cardboard...mine was a hard plastic...kinda like a fiberglass...
    But basic failure is the foam backer starts to fail...it turns to dust (ever see old carpet padding go bad...same thing)....once it starts...NOTHING will fix it.
    IMO reusing the factory fabric is a fools game...but you can buy some pretty good looking stuff...glue it up in a big sheet with lots of excess...then trim...really the ONLY WAY...
    Trying to squirt dabs of adhesive through the old headliner to reglue it looks about as bad as pins, staples, or other tricks IMO.
  12. ZippyNH
    P.S.
    While you are doing the headliner reglue, be sure to check and reconnect you sunroof drains if you have a sunroof...adds about 2 minutes to a couple hour job!!
  13. DixonL2
    DixonL2 New Member
    274
    A bit north of the 'burgh, PA
    And choose a cool fabric to do this with if that drab OE grey just doesn't do it for ya. There is definitely an adhesive for the job. Set out 2 sawhorses, clean the old crud off thoroughly, spray on adhesive, and gently (without stretching) lay the fabric over the adhesive-soaked panel. Helps to practice with a partner before putting the sticky stuff on. Allow to set, trim to fit (leave excess at the edges to tuck in), reinstall.
  14. slipmagt
    slipmagt Member
    Aug 23, 2015
    32
    6
    Yeah if your going to go through all the trouble of taking it out, its a great time to customize it up and use whatever fabric you like.
