Interior 1st Gen Headliner
Discussion in 'Tuning and Performance' started by ole97texas, May 12, 2012.
  1. ole97texas
    ole97texas New Member
    Jun 29, 2011
    MINIster
    Texarkana, Texas
    The headliner on our 04 MCS is starting to come lose on the edge at the passenger's side. Can this be reattached or will the headliner need to be replaced? If replaced, upholstery shop or are there diy options?
    If you put some spray glue on a paper plate then you can use a small brush to put a small amount up where it is coming loose. Let's it get tacky first then lightly put the headliner back in place. Don't press it on hard because any wet glue will bleed through the fabric.
    To hold it in place you can use a little painters tape around the edge. It sould fully dry in about an hour.
  3. ole97texas
    Jun 29, 2011
    MINIster
    Texarkana, Texas
    Thanks Dave. Will do.
  4. SHAMROCKTRIM
    SHAMROCKTRIM New Member
    Custom Auto Upholstery
    Davie, Florida
    Do not try to glue, the headliner material is thin and the glue bleeds. The headliner needs to be removed from the car and cleaned. Then new material is glued to the board. I always tell customers if they don't want to repair use fitting pins on the edge to hold in place. I have recovered five mini headliners in the last few weeks. I try to talk the customers into using black instead of the standard grey, which creates a two tone custom look. In South Florida, most shops are charging $175 to $250 to replace the headliner. If you go to my web site, click on headliners and I explain it a little more. 2040 ne 154 st |  North Miami Beach, fl 33162 | 305-944-3621 |  M-F 7:00-5:30      - shamrock auto trim You could always remove the headliner, take it to a local upholstery shop and let them glue the new material. Good luck!
  5. Dave.0
    I have done this many times. A MINI is not a 57 Chevy iyou do not need to use fitting pins. 3M headliner spray glue is made for....you guessed it headliners.
    This is a spot fix not a full repair. Read my instructions again. You have to let the glue dry until it is tacky then lightly apply the fabric to the glue, no pressing to prevent glue bleed through.
    Who needs a $175- $250 repair when you can fix it yourself in 30 min with a $10 can of 3M headliner spray glue.
  6. SHAMROCKTRIM
    Davie, Florida
    I am sorry, you are right! I was just trying to help, the ten dollar spray will fix it.
  7. Metalman
    Don't feel sorry.... Your input was appreciated..... It's good to get several suggestions.... :D
  8. Justa Jim
    No need to be sorry at all. Most of us here on M/A friendly and like suggestions. You seem to be in a position to offer good advice so keep posting. :Thumbsup:
  9. ole97texas
    Jun 29, 2011
    MINIster
    Texarkana, Texas
    What are 'fitting pins' & where can I find them?
