Brakes Wheels 1st Gen Tires Health & safety warning.....
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Crashton, Aug 9, 2011.
    I read this over on the Miata site I frequent. Scary stuff for sure. Take a minute & read it. I posted in the Brakes area because it involves brake clean.
    Brake Cleaner = Phosgene Article
  2. SNEEEZY - Erika
    1,212
    116
    Female
    It definitely made an interesting read...but how many people will use argon gas + excessive heat when cleaning brake components?
  3. Onramp
    Onramp Enjoy the Hiways of Life!
    Retired, mostly
    Renton, WA
    Wow. Wow.
  4. docv
    docv Well-Known Member
    818
    280
    moble auto paint tech ( PTU )
    Central Missouri
    Good article, very scary stuff. Anytime you work with automotive solvents/cleaners or the stuff under your kitchen sink if not used correctly can be deadly.
    Thanks for posting.
  5. Rae
    Rae Club Coordinator
    Oct 14, 2010
    907
    Oregon
    We use brake cleaner all the time for stuff. Including cleaning the windshield of the LeMons car this weekend since I accidentally oversprayed it with spray paint. Not anymore, back to razor blades I go!
  6. docv
    818
    280
    Central Missouri
    #6 docv, Aug 9, 2011
    Removed
  7. ScottinBend
    That is certainly a wake up call for thinking about what you are using on a car and making sure you are using the product for the work it was designed for.
    Just read the article and well...it sure does make me think twice about some of stuff I do.
    Thanks for sharing this.
  9. Metalman
    #9 Metalman, Aug 10, 2011
    Good article Chuck, thanks for posting this. I'm aware of this issue in our shop. I took a quick "walk through" this morning. I buy the non-chlorinated spray which does not cause the phosgene problem.
    For those that don't know, this is the gas they used during WWI to gas the troops in the trenches in Europe..... Nasty stuff...
    So I end my inspection... To my horror I find one can of the same stuff pictured in the article (identical warning label). Asking around, one of my workers brought it in from home to clean a car part during his lunch hour and forgot to take it home. I've since disposed of the can...
    I've used brake cleaner for years & have never given a second thought to the warning label. This is a wake up call for me. Luckily for me I have been using the non-chlorinated stuff.
    I wonder why the author of the article did not call 911 & seek immediate help. Could have been he was in a stupor from the gas & couldn't piece it together that he was in very serious trouble.
  11. Metalman
    Just imagine being a worker, smoking a cigarette in an area that just had some tetrachloroethylene sprayed on a brake job, with the gasses passing over the hot ember of the cigarette. The phosgene would get you before the cancer.....
  12. iwashmycar
    iwashmycar Active Member
    Jun 1, 2009
    881
    87
    architecture
    Yeah if I ever have a 10-15 minute long siezure better believe im going to the hospital instead of "Phew, glad thats over, lets read up on it."
  13. quikmni
    quikmni Moderator
    Jun 6, 2009
    774
    174
    Aerospace Engineer
    Orcutt, CA
    Thanks for sharing the article. It did make be think that I need to be more careful when using chemicals.
