Hello from a new member P15DF & 0087 error codes
Discussion in 'Starting Line - New Member Introductions' started by JesseBee, Jan 22, 2017.
  1. JesseBee
    JesseBee New Member
    Jan 22, 2017
    I am a first time Mini Cooper owner. Although I am mechanically inclined I know next to nothing about the 2012 Cooper S I have recently purchased. I've only got about 3,000 miles on the car since purchased and it recently started throwing codes P15DF and P0087 both of which would seem to indicate, according to a forum member from 4 years ago that I need a new High Pressure Fuel Pump :mad:
    This pump appears to be quite expensive. Does anyone have any suggestions?
    Sorry I am no help but one of the gen2 guys will be along that can help. Welcome to MA!
  3. DneprDave
    P15DF: Fuel pressure 3.5 BAR lower than specified pressure.
    Potential problem source(s):
    - Fuel tank empty
    - Defective rail pressure sensor
    - Defect in low-pressure system
    - High-pressure pump defective
    P0087: Fuel rail system too low.
    The High Pressure Fuel Pumps used to be about $350, but MINI has jacked the price upwards of $1000.
    They are warranted past the car's warranty, but I don't remember which years are involved.
    Maybe it's the sensor.
  4. Metalman
    2007, 2008 & 2009 are covered with an extended warranty from MINI..... 10 years or 120,000 miles
  5. wjosh45
    wjosh45 Member
    Nov 20, 2016
    131
    JesseBee - welcome to MA.
    DneprDave - do you know if this fuel pump Mini specific or is there a cross reference part for a different car? Has anyone tried to figure that out?
  6. DneprDave
    It looks like it is a MINI specific part. There are three different part numbers, depending on the year of manufacture.
  7. wmwny
    4,040
    2,242
    Welcome to M/A! :Thumbsup:
  8. mrntd
    Welcome Aboard!
  9. wjosh45
    wjosh45 Member
    Nov 20, 2016
    131
    Ok - I'll look up the part numbers and see if they potentially cross reference to some other vehicles. I can't imagine a fuel pump cost this much.. wow.
