Hello
Discussion in 'Starting Line - New Member Introductions' started by 3whit, Jan 15, 2015.
  1. 3whit
    3whit New Member
    Jan 15, 2015
    Carpenter
    Bellows Falls Vermont
    Hope to find a solution here , CEL P 2187, Thanks in advance for any help . Car still runs fine . I did replace the HPFP this summer no trouble since .Then today in the Frozen Tundra of Vermont the Light Came on..
    What year and model MINI please.
  3. 00Mini
    2,228
    Welcome M/A the onlyest MINI forum you'll ever need !!
  4. wmwny
    4,048
    2,246
    Welcome to M/A!
  5. MCS02
    6,278
    Welcome to MA!
    I looked up that code. It said move south where it's worm. :D
  6. Dave.0
    Welcome to M\A the FUN MINI site. :Thumbsup:
  7. beken
    beken Well-Known Member
    Jan 13, 2010
    1,405
    1,829
    Delta, BC
    Welcome to Motoring Alliance.
    What year is your car? I believe P2187 means your car is running a lean fuel mixture at idle. Possible issue, your fuel pump is starting to go. You might also consider changing the fuel filter.
    The high pressure fuel pump is not good for "life of the car". In fact, most cars I have owned that have electric fuel pumps in the tank last just under 10 years.
    In my case, the fuel pump on my MINI died without warning. At least you got a code.
    You should have it checked out. Fuel pumps are not all that expensive. But the couple of hours of labor might be.
