MINI Help and some advice?
Discussion in 'General Technical Questions and Answers' started by Eric m Combs, Mar 18, 2019.
  1. Eric m Combs
    Eric m Combs New Member
    Mar 18, 2019
    2009 cooper s john cooper works. at 32224 miles lost compression in #2 cyl misfires in other cyls and exhaust going into crankcase. Dealer replaced the block and now, at 52252 miles the exact same problem #2 cyl no compression and exhaust in crankcase. of course, the new block the dealer installed had only a 2 year warranty. even with a used engine it will cost more than i spent on the car. I can't even think about a new engine $11000.00+. Can anyone give me some advice on what to do? I'm guessing that the only option is to sell it to an enthusiast as a project car. I cant think about a junkyard..
    6,315
    If you can’t bare to sale the car to a junk yard I would say you are an enthusiast.
    For the problem to return in just 20,000 miles I would say your dealer did not fix the the problem properly. But I guess that’s water under the bridge.
    Can you do your own work? If so you could give Allmeg auto parts a call
    https://www.allmagautoparts.com/
    and see if they have a motor. Then you can just move the accessories from your one engine to the new one. A JCW N14 motor is different than a normal N14.
    Have you had the car checked for carbon in the intake?
    It sounds like even if that was the cause it has bigger problems now.
    How often did you change the oil?
  3. Eric m Combs
    Mar 18, 2019
    Thanks so much for your response. I was posting the thread out of desperation for a solution. I am not able to do the work myself and the
    cost of a replacement engine and paying for it to be installed is just too much for the pocketbook to handle. I don't have a garage available
    to store the car , so my options are pretty limited. If no one in the group has any interest I can only list it on craigslist.
  4. 00Mini
    2,259
    Best of luck
