Brakes Wheels 2nd Gen Tires Help clearing up caliper confusion
Discussion in '2nd Generation: 2007+ R55 through R61' started by Vernon29RW, Jul 2, 2011.
  1. Vernon29RW
    Vernon29RW New Member
    May 22, 2009
    115
    Pat-Med, NY
    So I have an '05 S and just picked up a set of calipers off a R56. After reading a few threads on the other site about the conversion I noticed people are saying that the calipers from the old JCW kit are only the same as what's on a R56 S and are different between a cooper s and a justa. So now I'm starting to worry did I get the wrong calipers. So I looked up on RealOEM and the part numbers are the same for both cars. Does anybody know the truth here that could help me clarify this?
    Thanks,
    Steve
  2. minimark
    #2 minimark, Jul 2, 2011
    Deleted post. Unintentional thread Jack.
    #3 Crashton, Jul 2, 2011
    ole97texas keep looking. That MINI sounds like a rat.
  4. Vader
    Vader New Member
    Oct 7, 2009
    45
    When you are looking at the realoem parts list, compare the part numbers for the brake carrier, not the caliper. You should see a difference between the justa and S. I believe the caliper part is identical but the mounting is different (carrier) because the rotor diameter is different between the two.
  5. Vernon29RW
    May 22, 2009
    115
    Pat-Med, NY
    I'm not confused about the differences between the two entire brake setups. I understand that a R56 justa rotors and pads are different than a R56 MCS. I'm just wondering about the actual calipers. Are they different on a R56 justa cooper than a R56 MCS? According to RealOEM they are the same part numbers. I understand the carriers would be different due to different sized rotors. Same goes for the pads, maybe different material. But why change the actual caliper as well??
  6. Professor
    Professor New Member
    69
    BMW / MINI tech
    Kentucky
    This is not correct. The R56 Justa brakes are not the same as standard R53 brakes.
    R56S brakes are the same as R53 JCW
    R56 Justa uses the same caliper as the R56S but a different mounting bracket to be able to use a smaller rotor.
  7. Professor
    69
    BMW / MINI tech
    Kentucky
    You are correct, it is the same caliper from R56S to the R56 Justa, but they do have different carriers.
    Interesting! I stand corrected. Thanks for setting this old guy straight. :Thumbsup:
  9. Vernon29RW
    May 22, 2009
    115
    Pat-Med, NY
    Thank you Professor. I emailed the guy I bought them from and he told me they came off a 2007 MCS so looks like I'm good.
    Thanks,
    Steve
  10. BlimeyCabrio
    Then you should be good.
    You WILL need some custom front brake lines to make it work... they need the R56 caliper end and the R53 car end... Or maybe 1st gen JCW lines (which I assume are the same, but not 100% positive). Dan at Grassroots Garage had some custom lines made up for me.
    But the 2nd Gen MCS brakes is a HUGE upgrade for 1st gen cars. I LOVE mine. Night and day difference. I ate Carbotech pads like skittles at the track and the Dragon with the OEM calipers and rotors. No problems since I swapped to the 2nd gen setup.
  11. KC Jr 54
    KC Jr 54 New Member
    Jun 3, 2009
    402
    20
    Machine Operator
    Tyler, TX
    As far as brake lines, you'll just need a set of 2nd gen brake lines and slightly modify the mounting of said line on the body-side of the line. Very minor and very easy to do. Personally I got my lines from WayMotorWorks and they do their job just as they should.
  12. TheMadDane
    TheMadDane New Member
    Mar 26, 2011
    Napa
    You can get stainless brake lines that will match up perfectly at: autoxcooper.com $47.50 for front or rears!
    No affiliation, just used them to buy mine.
  13. Vernon29RW
    May 22, 2009
    115
    Pat-Med, NY
    Yeah I already got a set of lines from Detroit Tuned. I just got a set of R56 lines. I was under the impression that the car side is the same between a R56 and a R53 just the caliper side is different. Am I wrong? If I am what is different on the car side?
  14. Professor
    69
    BMW / MINI tech
    Kentucky
    I am running the Detroit Tuned lines for an R56 and had no issues mounting them to the car and caliper, no mods were needed.
  15. Vernon29RW
    May 22, 2009
    115
    Pat-Med, NY
    That's what I thought! Once again thank you much sir. Very appreciated.
  16. KC Jr 54
    KC Jr 54 New Member
    Jun 3, 2009
    402
    20
    Machine Operator
    Tyler, TX
    I guess it varies between whose lines you get. The lines I got mimic factory lines and had four little triangles on the car side fitting, and it wouldn't fit into the factory tabs. You are correct, the caliper side of the lines are VERY different and are what warrant the lines in the first place.
    I love the r56/r53jcw brakes, just need some better pads, and ill be 100% satisfied.
  17. ScottinBend
    Along the same lines.....I might be able to get my hands on a set of R56 JCW front caliper/rotors for cheap.
    Will these simply bolt up to my '04? Got some great threads, but I am still not certain these will bolt on w/o mods. I know the R56 calipers will work, just not sure about the JCW ones.
  18. Professor
    69
    BMW / MINI tech
    Kentucky
    The R56 Brembos work in the same fashion, simply use R56 brake lines.
  19. Vernon29RW
    May 22, 2009
    115
    Pat-Med, NY
    What are you running? I got a set of EBC reds. I was told that they work really great on the street and can hold up on the track (I'm only a beginner) for now, if I ever make it!!
  20. KC Jr 54
    KC Jr 54 New Member
    Jun 3, 2009
    402
    20
    Machine Operator
    Tyler, TX
    Currently just on stock OEM pads. Want to go to the Bobcats though, but hard to justify $170 for just a front set right now. Once i whittle these down a little more ill make the jump.
