Help! Code P0107! R53
Discussion in 'Starting Line - New Member Introductions' started by anialeh, Apr 26, 2017.
  1. anialeh
    anialeh New Member
    Apr 26, 2017
    2003 Mini Cooper S R53/W11
    So, I rebuilt the engine due to a cracked head 13,000 miles ago.
    Now I'm throwing code P0107 Barometric Pressure Low Emissions Small Leak and I've replaced my bypass valve (detroit tuning), checked and cleaned MAP and TMAP sensors, replaced downflow O2 sensor but my ABS is acting up like crazy with this code (I should mention that I have run-flat tires). I'm going to the shop I used to work at tomorrow to do a smoke test but if that's not fruitious, where should I go from there?
    I read a post here about the fuel float sensor but it shouldn't cause all these problems. I had heavy rain come through a cracked open passanger window that may have compromised the BCM 2 years ago which may be why my right side of the car (window, door lock and headlight don't work).
    My harmonic balancer is in check and so is the crank pulley (no wibbly wobbly vibration). I'm at a loss and registration is due.
    My dad is a mechanical engineer and has wracked his brain as to why I'm throwing this code (he sold it to me) PLEASE HELP! :(:fingerscrossed:
  3. MCS02
    I had the hoses plugged in but the plug.
  4. Qik
    Qik Well-Known Member
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    :postcount
