Engine Drivetrain 1st Gen Cooper S HELP ERROR
Discussion in 'Tuning and Performance' started by Nelson, Feb 15, 2012.
  1. Nelson
    Nelson New Member
    Feb 15, 2012
    Hi,
    Please need to know how to solve this error.
    Having reprogrammed the MINI Cooper S 170hp, only cold and appears this error P1685 and accelerator does not respond, someone can help me.
    Thanks a lot.
    What year MINI please.
  3. Nelson
    Nelson New Member
    Feb 15, 2012
    2005 is restyling
  4. Minidave
    4,594
    What did you reprogram? Explain "Having reprogrammed the MINI Cooper S" please?
    Where are you located?
  5. Nelson
    Nelson New Member
    Feb 15, 2012
    Once tuned ECU, started giving this error P1685, but this error appears only when the MINI is really cold, then heating everything is normal.
  6. Minidave
    4,594
    Whoever did your tune will have to fix this, it has to do with the electronic throttle control module...that's all I know.
  7. Nelson
    Nelson New Member
    Feb 15, 2012
    Thanks!:Thumbsup:
    Yeah, sounds like one of the issues that was found early on when Dimsport was first being used on the R53 to tune.
