1st Gen R53 Cooper S HELP, i need a Ball joint seperator that works.
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by 00zero, Jul 24, 2010.
  1. 00zero
    00zero New Member
    Oct 2, 2009
    92
    Pittsburgh. Pa
    I am trying to do my FCAB and im stuck.
    i am trying to get a ball joint seperator that works for the inboard ball joint. i got a loaner from advanced auto and it is too short.
    does anyone know of a brand that works or can be modified to work?
    -Jonathan
  2. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    Call up Keith at Werkin Mini
    he did an excellent "how to" that's on NAM and listed some parts that will do the job. I think there were NAPA units, but don't remember exactly.
    Matt
  3. Minidave
    Are you using one like this?
  4. 00zero
    00zero New Member
    Oct 2, 2009
    92
    Pittsburgh. Pa
    minidave: yes, that was the kind i was trying to use but mine was too short.
    Well i didn't get anything done this weekend, it has rained all day.
    So i am going to go on a hunt for the proper separator this week.
    If not i guess i will pull the cv joints like 002 on NAM recommends doing the fcab with out dropping the subframe or maby ill just drop the subframe while i do struts and springs.
    Does anyone know if it is possible to cut the old fcab out? i was going to cut a slit or two with a hacksaw and hammer it out, will this work?
    -Jonathan
  5. 00zero
    00zero New Member
    Oct 2, 2009
    92
    Pittsburgh. Pa
    thanks for the how to.
    i never though of looking at the 2nd gen stuff.
    lowering the subframe looks like a better solution than dropping it and easier than popping the axles, or ball joints.
    Hopefully i can get this done with struts and springs this weekend.
    -Jonathan
