Help identifying bolts after clutch replacement
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Hanns Irvin, Mar 18, 2021.
  1. Hanns Irvin
    Hanns Irvin New Member
    Mar 18, 2021
    #1 Hanns Irvin, Mar 18, 2021
    After finishing replacing clutch in r53, I have 3 bolts remaining. Hoping someone can help identify where they go.
    2 - specialized 13mm bolts
    1 - large 16mm bolt
    see pics
  2. 00Mini
    2,275
    I can’t help you with the bolts but I can welcome you to Motoring Alliance.
  3. MCS02
    6,328
    Those look like the bolts that bolt the transmission to the motor
  4. Hanns Irvin
    Mar 18, 2021
    Transmission bolts are 15mm - I have verified that both starter bolts, 7 transmission bolts, 10 subframe bolts, and 9 transmission mount bolts are installed
  5. 00Mini
    2,275
    Maybe someone tossed them on ground when you were working on the car like Carroll Shelby did in the movie Ford v Ferrari. :D:D
  6. MCS02
    6,328
    #6 MCS02, Mar 19, 2021
  7. Hanns Irvin
    Mar 18, 2021
    Found the 16mm M12x60 one...still looking for the other 2
  8. 00Mini
    2,275
    Good to hear. Where was it ??
  9. Hanns Irvin
    Mar 18, 2021
    Found the other two
  10. Hanns Irvin
    Mar 18, 2021
    The first one I didn't find because removal isn't required for clutch replacement. It is the drivers side inner ball joint bolt that is directly under the axle
    The other two go into the bracket that is mounted to the throttle body. M8x30-z1
  11. MCS02
    6,328
    Excellent sorry we weren’t much help.
