Brakes Wheels 2nd Gen Tires Help me decide...please
Discussion in '2nd Generation: 2007+ R55 through R61' started by Goldsmithy, Mar 23, 2015.
  1. Goldsmithy
    Jan 30, 2015
    1,748
    982
    TCB
    Main Street in the land of Oz
    I need to change out my r/f tires for non-run flat tires. The original tires have only 3,700 miles, but they are 10 years old and I don't trust them, even though they have been properly maintained.
    I have decided on one of the following tires, in 205/50/16.
    Pirelli P7AS
    Continental Premiere DWS
    Michelin Premier AS
    Winter driving will not be an issue as my car will hibernate during the winter. Also, I will have a 22mm rear sway bar installed at the Dragon.
    One thing I am interested in is 'road noise' and I can't find much info on this factor. As always, TIA for any help and information you can give.
    __________________
    I'm in complete agreement your runflats have timed out. There is no way to look at them & tell if they are still safe to use.
    The size you have chosen IMO is perfect for your MINI. Of the 3 tires you have listed I'd go with the Continental DWS.
    Read the reviews on Tire Rack to find out if this tire is quiet enough for you. Keep in mind that ant tire will get loud if you do not rotate it enough.
    Buy yourself a Slime Spare Tire kit. It includes a compressor & some plugs & fix a flat. You can pick it up at Wally World. You probably won't need it, but it is a good thing to have on hand.
  3. ScottinBend
    If you are going to hibernate, don't waste money on the all-seasons, go with a summer tire. Your sway bar will love you for it.
    Check out the latest max/extreme summer tires at Tire Rack.
    Depends where the OP lives. If they drive in cold but clear weather summer tires don't work well & can be dangerous.
  5. myles2go
    myles2go Active Member
    May 7, 2012
    589
    223
    collecting a paycheck
    WI
    The DWS's are a nice tire, but if you don't need the snow capability look at the DW's.
  6. mrntd
    I've been happy with the DSWs they have lasted a while and are quite. I've had a bit different P7 version in the past. Performance was great but they didn't last long.
    When the DSWs are done I'll be going with a 3 season tire. I have a separate winter set.
    I've had a set of P Zero Nero tires. They worked well when new, once the new wore off they were terrible, very prone to hydroplaning.
  8. MCS02
    I really like my Bridgestone Potenza RE760. They are Ultra High Performance Summer but I have used them in the winter, I live in the south so it doesn't get below freezing often.
    I have had them two years. I rotate them with oil changes, every 3000 miles.
  9. B.A.D.
    I just ordered these last week for my GTI. How have you liked them so far?
  10. MCS02
    I have really liked them. I rotate them often I have found this keeps them from cupping. They are very quit and have lots of grip dry and wet.
    I don't have winter tires because where I live so I did drive them in snow and ice. They did fine but are not made for those temperatures.
    I think you will like them.
  11. Ronbo
    Ronbo New Member
    Feb 10, 2013
    196
    106
    New Albany, Ohio
    I've run the DSW for a couple of years and like them a lot. Great snow/ice traction and plenty of performance for the type of driving I do. Last summer I purchased a set of Konig Feathers and had the DW's installed. Good dry/wet performance, but a bit noisier. Both of these tires have been around for a while. so I'm sure there's some out there with newer "technology", but the Conti's seem to give alot of value for $$$ spent.
  12. Dave.0
    If you store your MINI in the Winter and do not drive it at all get a good set Summer tires and skip the "All season" tires. The are pall just ok but good at nothing.
    Dunlop Star Specs and Michelin Super Sports are excellent. Conni DW's are only ok once you have drove a car hard on Dunlops or Michelins I listed.
    I have had about 10 different tires and may of the ones listed above and the only tire I have bought a second time was the Dunlop Star Specs which are currently on my car. :Thumbsup:
  13. Goldsmithy
    Jan 30, 2015
    1,748
    982
    TCB
    Thanks for all the knowledge guys. I am going with the Continental DWS in 205/50/16.
    I think you will be happy with those. Keep in mind you will need some miles on them to scrub them in. Brand new tires feel a might squirmy.
  15. Savvy
    I've run 205/55/R16. The little bit of extra sidewall never hurts. Plus, it helps to bring the speedo error down a bit.
    The 205/50 will make it a bit worse, iirc, they are touch smaller than the 195/55.
  16. CHKMINI
    I just bought a set of the new Potenza RE 71 R. With a UTQG of 200 A A they feel like erasers. It's hard to find Extreme Summer Tires in 215/40 18 so when these were released a few weeks ago I jumped on them.
  17. Crashton
    When I ran 205-50-16s on my MINI the GPS indicated a speedo error of +3 MPH. That was close enough for me.
  18. minintrigue
    minintrigue Active Member
    Sep 30, 2009
    233
    Banker
    Cincinnati, OH
    I'm ordering a set of the Michelin pilot A/S 3 next week for my MINI. I'm putting the conti DWS on my Q7.
