Help me please!!
Discussion in 'Starting Line - New Member Introductions' started by 03cooper, Mar 11, 2015.
  1. 03cooper
    03cooper New Member
    Mar 11, 2015
    Okay so I just got this o
    03 mini cooper, n/a. This isn't my first had a r56 I think an 07 turbo. Anyways my throwout bearing is shot making a bad shearing noise and goes away almost imedietelty when not in gear or clutch is down. And I'm not sure which to get. EBay's my option otherwise clutch masters would be it. I'm willing to spend enough for a stage 2 or better than stock and should I get a kit with a flywheel? Idk just stuck need opinions and good/cheap/reliable brands. Haha names Dillon and hope someone can help me out eaaasee. And yes I'm doing the work myself
    Call Eric at Helix or Chad at Detroit Tuned and they can give you options better than Ebay clutchmasters crap.
  3. wmwny
    4,048
    2,246
    Welcome to M/A! BTW, I agree with what Dave.O suggested!:Thumbsup: Perhaps you could tell us where you are communicating from, in the meantime.
  4. MCS02
    Welcome to MA!
  5. TheModFather
    Just put another stock clutch in it. You cant make enough torque in an R50 to need a higher performance one, and the only good reason would be to replace the weak TO bearing with a better one. None of the aftermarket makers upgraded the TO bearing on the R50 clutch kits though.
    Unless you slip the heck out of it all the time, ride the clutch pedal, or abuse the TO bearing, the stock clutch lasts quite a while to.
  6. 00Mini
    2,228
    Welcome to Motoring Alliance the only Mini Forum you'll ever need as you can see by the answers you already received.
  7. mrntd
    Welcome Aboard!
    What TheModFather said
  8. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    ^Nuff Said^
  9. 03cooper
    03cooper New Member
    Mar 11, 2015
    Thank you guys for the help much appreciated. Seeing how a woman owned this car before me lol and it was in a couple burnout comp I guess so reason being for shitty TO.
  10. Nathan
  11. eMINIparts
    eMINIparts Well-Known Member
    3,751
    1,087
    MINI Parts Advisor
    Bedford NH
    Welcome to the coolest MINI forum on the net....................:cool:
  12. RallyMini370
    hold on this is a Midlands box. the noise is there when in neutral? or goes away with the clutch down? oh welcome.
