Help on AutoX setup
Discussion in 'Autocross' started by MCS02, Apr 13, 2012.
  1. MCS02
    Hi
    I may be going to a autox tomorrow and need some advice.
    I have have Eibach Springs, and Koni 3 way adjustable shocks with Falkan E912 215/40.
    Does anyone have any advice on how stiff I should make the front vs the rear and a good tire pressure to start with.
    Thanks
  2. grodenglaive
    grodenglaive New Member
    Apr 3, 2010
    313
    68
    Ottawa, Ontario
    Never driven those tires, but 36-38 psi cold is a safe bet. Chalk your tires, if they roll over a lot add a couple more psi. Aside from that, if it's your first autox it won't really matter what you do with the shocks.
  3. MCS02
    Along time ago I use to autox a Fiat X1/9. But that was a life time ago. I have only autox my MINI a few times that was over a year ago, and I did not mess with the shocks.
    This is a BMW vs MINI event and I'm looking for any advantage I can get.
    I know the biggest problem is the loose nut behind the wheel. :arf:
    Thanks
  4. goaljnky
    3,105
    394
    Stiffen the rear up so the car rotates a little faster. Otherwise I'd make a run, or two and adjust from there.
  5. dr61
    dr61 Member
    Oct 9, 2011
    30
    6
    Redding, CA, USA
    front soft, rear firm on the shocks. Tire pressures to start: 40 front, 52 rear. Sometimes 40 front, 32 rear depending on tire characteristics, but usually the higher rear will allow more rotation. Try both, but do at least 3 runs each before changing.
  6. MCS02
    Thanks for the help. I'll try not to shame the MINI name
