1st Gen R53 Cooper S Help! on my honeymoon! Idle problem and more!
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by r53juggernaut, Jun 18, 2013.
  1. r53juggernaut
    r53juggernaut New Member
    Apr 19, 2013
    11
    Hey everyone! Hope everyone is doing awesome! I am in need of a little help. I am on my honeymoon in Harrisonburg va but Stella (my r53) is trying o make my life difficult. I think the throttle body is shot (so ill buy someone's extra) but here are the symptoms: wont hold idle. Studders when at a cruising speed. Eml light comes on for about 15 seconds on start up. Seems to be greatly losing power but wot seems fine. Traction control automatically turns of and locks in the off position. Any help would be greatly appreciated. Ps I had a leak that allowed water in behind the dash on the drivers side. I fixed it and this happened after. Idk if they are related.
    Thanks all!
  2. Jason Montague
    :cornut: Congratulations on your wedding. No help here but someone 'in the know' should be along shortly.:Thumbsup:
  3. Minidave
    4,592
    I think you may have identified the source of your problem (the water leak behind the dash) but I can't tell you what to fix......if it's leaving a code you can stop by any chain auto parts store and have them read it for you, that might point you in the right direction......good luck!
    If I had to make a guess I'd look for corrosion, especially on a ground connection.
    And congrats on your marriage.
  4. r53juggernaut
    Apr 19, 2013
    11
    Ill get the numbers ASAP. But Codes keep jumping. I had lean condition 1 count. Map sensor error 0 count. Throttle plate error (or something like that)
    The other that popped up and then disappeared was a 2/3 torque reading. I took the intake intercooler and all accessible top plugs off and saw nothing odd. Put it all back together and it ran great for one day. Now it's all back
  5. Minidave
    4,592
    Double check all your battery connections, especially the grounds. Don't forget the short ground cable by the right side motor mount bracket.
  6. fngolfer
    fngolfer Active Member
    Apr 1, 2012
    100
    46
    Los Angeles
    Battery
    If you're in a pinch, try disconnecting the battery a while and let the computer relearn Stella. If that doesn't work, try some Pino Grigio on the new bride. Works for me. Good luck.
  7. Jason Montague
    :yikes::yikes::yikes::lol::lol::lol::lol::lol::lol: I'm rolling in the floor!(but I'm sure that he's not)
  8. BThayer23
    Sounds like you're moving in the right direction. Check that sensor connections are plugged in, too, like the accelerator pedal, the throttle body, and the camshaft position sensor.
  9. FranticFreddy
    FranticFreddy Drive-N-Eat
    325
    Some Where between here and there.
    I can see this thread drifting real fast............:ihih:
  10. quikmni
    quikmni Moderator
    Jun 6, 2009
    774
    174
    Aerospace Engineer
    Orcutt, CA
    Also check the fuse box (engine compartment) to make sure all the relays are well seated. Sometimes they can vibrate a little loose.
  11. jeffster06
    jeffster06 Active Member
    Apr 23, 2010
    420
    111
    Dallas, GA
    When my throttle body went bad on my R53 it would randomly go into limp mode with a CEL and EML light on. it did lock the traction control off one time though. whenever it would do that I got by for the longest time by pulling over unplugging the throttle body cable and plugging it back in.
