HELP PLEASE Mini Cooper S 04 won't start
Discussion in 'Starting Line - New Member Introductions' started by Lynn66, May 18, 2017.
  1. Lynn66
    Lynn66 New Member
    May 18, 2017
    Hi everyone I'm hoping someone somewhere can shed some light on this. Here goes :-
    Left my car in gear when parked forgot when I started it and stalled quite violently and now won't start. Turns over fine just wont fire up. Called AA who came out and said its the inertia switch and it will need a garage to sort it but since been told that from 02 upwards these cars don't have inertia switches. Can someone please please help me out on what could be the problem?
    Only had the car 2 weeks but been fine til now and I love it.
    Thanks in advance Lynn
  2. ScottinBend
  3. Minidave
    4,591
    The inertial switch (if it has one) is on the left between the master cylinder and the inner fender, there is a large black button on top - push it down.
  4. ScottinBend
    Inertial = clutch switch?
  5. DneprDave
    No, The clutch switch is on the clutch pedal linkage. The inertial switch has a weight and spring set up to trip off of the fuel pump in case of an accident, so fuel doesn't spray all over.
  6. Dave.0
    Bad or the wrong plugs will cause this issue. Also a bad ground under the hood.
  7. HillbillyChili
    Jun 14, 2017
    91
    29
    Software
    Do you hear the fuel pump running? If it turns over and over but doesn't catch it could just not be getting fuel. Either the fuse or the actual pump might be burned.
  8. wmwny
    4,048
    2,246
    Whole I cannot shed any light on fixing your problem, I'd like to welcome you to M/A, where most of us [except me] can offer some helpful hints. Good luck and enjoy your MINI once the problem is solved!
