2nd Gen R55 Clubman Help please
Discussion in '2nd Generation: 2007+ R55 through R61' started by Lovemymini1, Jul 6, 2017.
  1. Lovemymini1
    Lovemymini1 New Member
    Jul 6, 2017
    Rhode Island
    Hi I have a 2009 Clubman S. a week ago it started wanting stall when I came to a stop and it studdered a little when I pressed on the gas. today when I came to a stop it stalled. it has 46k miles on it I am the second owner have never had any major issues , I am not a mechanic and not sure what to do. My mechanic is on vacation and just trying to get some info wondering if this is common and what it may be. thanks. :eek:
  2. HillbillyChili
    Jun 14, 2017
    91
    29
    Software
    Is it getting fuel? I would check the valve on the fuel rail and see if a bit of fuel squirts out the end to make sure it is getting to the engine.
    Have spark plugs ever been replaced? If not it might be about time and that might help.
  3. Redbeard
    1,636
    398
    Glorified spreadsheet jockey.
    How long have you had the car? Have you noticed any decrease in gas mileage or loss of power prior to it stalling?
    The engines from that generation have a know issue with carbon build-up on the valves. It can cause the symptoms you're having now.
    I had a thread about this very thing many years back. I don't know if it's still in the forum though.
    I'd recommend taking it to a good MINI mechanic that knows these cars for a diagnosis. Don't throw parts & money at your car hoping something will stick.
    I thought the HPFP (high pressure fuel pump) was problematic on those cars. That is just a guess.
  5. MCS02
    Isn't there a extended warranty on some of the HPFP?
  6. MCS02
  7. Redbeard
    1,636
    398
    Good Call. I forgot about the HPFP. Mine was replaced during regular maintenance and I never had an issue.
  8. MCS02
    He may be an old fart but he is a useful one!:D
  9. HillbillyChili
    Jun 14, 2017
    91
    29
    Software
    Take it to a mechanic?? What is this world coming to, now is the time to dive on in and learn about your mini.
    Once you tear it apart and can't put it back together then it's time to go to a mechanic.
    The days of diving in without much knowledge & having a good outcome are past us I'm afraid. The French engines MIN I used are a complex affair to be sure. As I get older I learn my limitations & act accordingly. Please feel free to throw your money where you like. Hey how about throwing some my way? :smilewinkgrin:
  11. HillbillyChili
    Jun 14, 2017
    91
    29
    Software
    But then you could have a new HPFP, fuel pump, fuel filter, spark plugs, ignition coil and still have a non-running car and an empty wallet. Doesn't that sound better than having someone qualified look at it?
    Did I mention bloody knuckles???
  12. MCS02
    Every time I lift the hood of my wife’s R57 or the R58 I just shake my head and dread the day I have to do a deep dive into one of them.
